Lipo pack in TX (GT3B)
  • Mattwarner
    • Aug 2011
    • 495
    I am looking to move away from AA's and use a 3S 1300mah lipo in my GT3B, would someone be able to post a pic on how and where i solder the connections inside the battery tray
    Thanks!
  • Boaterguy
    • 1779
    think of it like a bunch of cells wired in series, the last negative will be your negative, and the positive on your other end, they will be the only tabs that aren't "double", or connected to the opposite polarity of the next cell.
    • Diegoboy
      • Mar 2007
      • 7443
      Is the reason because the AA cells dont last very long?
      • Mattwarner
        • Aug 2011
        • 495
        Nope, Its just a lipo pack is about the same price as 8 AA's therefore it makes sense, plus i can top up the lipo to make sure its always fully charged.
        • Diegoboy
          • Mar 2007
          • 7443
          I don't have that radio, but you can look HERE for some info.
          • BHChieftain
            Fast Electric Addict
            • 2051
            I like nimhs in my tx-- no memory effect so I can top off plus I don't need to worry about running them down too low. I also like to keep all of my lipos stored in my woodburning stove or fireplace.
            Chief
            • DPeterson
              • 991
              Been using these MAX AMPS for a couple years now. Very nice.
              http://www.maxamps.com/search.php search for lipo-2500-111-FUTX-flat-pack
              Doug
              Doug Peterson
              IMPBA 19993
              www.badgerboaters.com
              • Diegoboy
                • Mar 2007
                • 7443
                Thanks Doug.
                Link http://www.maxamps.com/Lipo-2500-111-FUTX-Flat-Pack.htm
                • Mattwarner
                  • Aug 2011
                  • 495
                  thanks!
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 7708
                    Here's how I did mine
                    One thing I found, is that once the screen autodims, it's hard to tell if you shut it off after use. Here's a mod to remind me to shut it off :
                    • Drax21
                      • Jul 2011
                      • 1077
                      I have been using Energizer Ultimate Lithium AA. Have used the Tx 8 times now and voltage in the cells has hardly changed. Was 14.2V Now 14.1. Should last a while but I definitely think the Lipo packs will save you money.
                      • leebrushless
                        • 13
                        Good mod. Where did you hook it in & what LED did you use, if you don't mind sharing? Thanks Leigh
                        [ATTACH=CONFIG]69391[/ATTACH]
                        http://www.youtube.com/watch?v=8jUfxgIZxsA
                        JAE FE rigger, ul-1, 4s.
                        JAE Gas rigger, in progress.
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          HERE's a site with easy to follow info on firmware for this radio. Some of the changeable features include...
                          •3-8 Channels
                          •Trim
                          •Sub-trim (All channels)
                          •EPA's (All channels)
                          •Adjustable Backlight timer
                          •Inactivity Alarm
                          •14 Model Memory
                          •Calibration Menu
                          •ST and TH Dead Zone
                          •Channel Speed (All Channels)
                          •Dual ESC Mixing
                          •4WS Mixing
                          •Multi Position Switches
                          •Key Mapping
                          • leebrushless
                            • 13
                            Thanks.
                            • Diegoboy
                              • Mar 2007
                              • 7443
                              Originally posted by leebrushless View Post
                              Thanks.
                              You're welcome!!
