Motor mounting Hole Spacing?
  • Snowride
    • 297
    Being relatively new to boats I am only familiar with 36mm diameter motors. When you get into 40mm or even 56mm are the mounting holes spaced the same distance apart between any 2? what about actual screw size? Do they remain the same or get bigger?
  • Chilli
    • 3204
    If the spacing is more than the standard 36 the holes are still spaced with the shaft centered between them. The larger Neu's use 4mm screws.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • dana
      • Mar 2010
      • 3660
      snowride. i believe theyre all 25 mm spacing. check the specs tho, i think most have the spacing posted.
      • Chilli
        • 3204
        You're right. I didnt get enough sleep last night. LOL
        The most popular spacing is 25mm. Then it goes up to 30mm on larger Neus. Don't know about brands.
        Mike Chirillo
        • Snowride
          • 297
          Thanks guys, tried looking up a few but did not see bolt hole spacing dimensions. So basically a flat aluminum plate with a large centre hole (for shaft) and 2 holes spaced 25mm apart becomes a universal motor mount right?
