Strut - rudder setback confusion
  • Goonboy2
    What me worry?
    • Aug 2011
    • 35
    Am I missing something?
    If the default strut for mid size monos is the 82.5mm long Speedmaster Stinger Strut - why doesn't Speedmaster make a 3 1/3" offset bracket for their long rudders - 21, 40, 1", dual taper? Is the only option to cut off the strut or make a longer transom mounting bracket for the 2 14" setback rudders?
    Hammer rescue boat on 2S, Supervee on 4S, Rico 31 under construction on 6S
    HO train on DC power, Nirvana II on wind power, antique phonographs on wind-up power
  • BrianW
    Rocket City Racing
    • Aug 2011
    • 100
    I have 3" Bearing Blocks
    • siberianhusky
      • Dec 2009
      • 2206
      There is no default size, they need or should be trimmed according to the length of the boat.
      There is a lot to be gained by having a proper strut or stinger length, once I set the length on one of my monos I was able to take off the trim tabs and the boat runs better. That doesn't alway happen.
      All part of the bunch of little things that add up to a great running boat.
      I'll either make up a new rudder standoff from aluminum if I need shorter or I'll add a pad of hardwood and use longer bolts that go through everything and hold it all together along with epoxy if I need to go longer.
      Eventually I'll own a small milling machine, would probably pay for itself in a couple years just in RC boat hardware!
