my fisrt jae 21fe
  • Serpents811
    • Oct 2011
    • 381
    my fisrt jae 21fe
    ok guys , im putting together a new rigger jae 21fe and i need some advice as far as which way should i go with it ,,, this is what im planning use to start ,,,,,,,
    seaking 120amp
    leopard 3674 3270kv
    (to start 3s1p or 2s2p)
    prop (??????) need advice on that
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    I think the motor might be a bit big. I'd go with the 28mm size motor
    • Serpents811
      • Oct 2011
      • 381
      i know i will have to mod the tub to fit the motor but thats all i got for it
      • Rumdog
        • 6453
        28mm for a JAE 21FE?
        I'd go with a 4s setup and spec power. They rock with the UL-1 motor.
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          Sorry. I saw 12. I even went in the boat room to see the 12 tub size. damn dyslexia
          • Serpents811
            • Oct 2011
            • 381
            i wont be racing it , its more sport racing with buddies but i want this thing to rock some gas jae21 at my local pond
            • Diegoboy
              Administrator
              • Mar 2007
              • 7247
              Like Rum said, The UL1 power plant will work well in the 21. (not 12).
              • Serpents811
                • Oct 2011
                • 381
                ok maybe in the near future ul1 motor will be and as far as prop goes
                • Diegoboy
                  Administrator
                  • Mar 2007
                  • 7247
                  on the UL1 power, I like the 1450 mod prop
                  • Serpents811
                    • Oct 2011
                    • 381
                    i dont mean to sound stupid but whos that prop made by
                    nevermind octura
                    • Diegoboy
                      Administrator
                      • Mar 2007
                      • 7247
                      It's stamped with TFL
                      • Chilli
                        • 3067
                        The ABC H7 is also a popular racing prop for UL1 power in the JAE.
                        Mike Chirillo
                        www.capitolrcmodelboats.com
                        • siberianhusky
                          • Dec 2009
                          • 2184
                          Zippkits prop.
                          I'm building one now as well, UL-1 motor and 4s 5000mah packs. Basically the power system the boat was designed around. I know all the component locations will be right so I can set the CG right without any issues.
                          If I was going with a long can motor I might think about moving the motor towards the bow a bit to take into account the extra weight.
                          I like the keep the most mass as close to the CG as possible, instead of having all the weight at the ends of the boat.
                          • Doug Smock
                            • 5264
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • martin
                              • 2869
                              Re cg position on JAE hydros, i spoke with Rod Geraghty one of the designers of the JAE team about this very subject. I was fitting a larger motor & esc which altered the cg position. He said the JAE design boats were very forgiving on cg position & it would be fine. Martin.
