Carbon Fiber Genesis Motor Setup
  • bracka69
    • 303
    Ok thanks nata2run i will definitely look into that and i also have a offset bracket for my rudder coming from fightercat racing for this also.
    • HYDROJERRY
      • Jan 2010
      • 2709
      Foregive me if im jumping in and havent read the hole thread but if it helps i run my Genesis with a Leopard 4074 2200kv, SF 200a esc, two 5s 5000 lipos in parallel and on a M445 prop and am getting mid 50's,,,, gets worm after awhile of running cuz it will run along time and my strut is even with the ride pads and no hop..
      • bracka69
        • 303
        Thanks HYDROJERRY for your response. I have the strut where it is even with the pad but when i get up to fairly high speeds annd give it all it tends to pull to the right very hard and spin out even roll over sometimes. I'm not sure if this is from the torque of the motor or what, but i will try the ofset rudder to see if that helps.
        • HYDROJERRY
          • Jan 2010
          • 2709
          Mine was (is) doing the same, i found my stock servo mount was loose so i reglued it and just to see, i put a stronger connecting rod from the servo to the rudder but its cold and rainy here so i havent gotten to try it yet but if the offset rudder thing works on yours let me no, ill have to do the same to mine...
