Which ESC for a serious 2S setup?
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    I just fount THIS page again, it says 3S.
    Tower hobbies probably gets their specs from the mfgr, which explains why tower says 3S too.
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      It also says 5 cell NiMh (6v) odd??
      Maybe the LVC won't work properly on 2S?
      • Darin Jordan
        • 8332
        How much do you want a bet that, if I pull out the original specs that were provided in the ESC Box... it's says 2S??
        Either way... that's what I used...
        Darin E. Jordan - Renton, WA
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          If you'd be kind enough to do that Darin, I'd appreciate it.
          • Darin Jordan
            • 8332
            I'll have to see if I can dig them up... I usually keep that kind of thing.
            I also still use my old CC Barracuda 125 ESCs on 4S without using a separate BEC or RX pack... so what do I know...
            • RaceMechaniX
              • 2825
              The CC 240LV does work on 2S with no problems.
              TG
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
              • lectriglide
                • 538
                Link to manual - 2 to 6 cell LIPO
                • sundog
                  Platinum Card Member
                  • Feb 2009
                  • 878
                  Is the CC240 LV a 2S ESC? I always thought it was a 3S?
                  Yep, it's good for 2v to 6v. That's why I recommended it to you Danny. Here's the manual - look halfway down the left side of the first page.
                  It's good for up to 3S when using the BEC; up to 6S if you disconnect it. But I hear they won't warranty it if used on over 4S now.
                  Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
                  • Darin Jordan
                    • 8332
                    Originally posted by sundog View Post
                    Yep, it's good for 2v to 6v. That's why I recommended it to you Danny. Here's the manual - look halfway down the left side of the page.
                    http://www.castlecreations.com/suppo...user_guide.pdf
                    So, it says in this manual that the BEC is good to a MAX of 3S... but it shows the voltage from 2-6-cell lipo:
                    1.0 Features of the HYDRA™ :
                    • Extremely Low Resistance (120 is .00043 ohms; 240 is .00022 ohms )
                    • Up to 120 or 240 Amps continuous current
                    • Water cooled heat sinks (see section 6.0 below)
                    • Massive 10 gauge wire on Hydra 120 and double 10 gauge wires on
                    the Hydra 240.
                    • 12 cells (3s lipo) MAX with BEC
                    • Six to twenty cells, or 2 to 6 cell Lithium Polymer packs
                    • BEC (3A) provides power to receiver and
                    servo - eliminates separate receiver battery
                    • User Programmable Features:
                    · Reverse Type
                    · Reverse Throttle Amount
                    · Low voltage cutoff (LiPo safe)
                    · Timing Advance
                    · Starting Power
                    • Safe “power on” arming program helps prevent motor from accidentally
                    turning on. Always use extreme care with high power systems.
                    • Auto shut down when signal is lost or radio interference becomes severe.
                    • Darin Jordan
                      • 8332
                      The bottom line is that the CC Hydra 240 does WORK with 2S just fine...
                      • Diegoboy
                        Administrator
                        • Mar 2007
                        • 7247
                        Then the CC240 lv it is. Thanks Guys!!
                        • Doug Smock
                          • 5264
                          Originally posted by Meniscus View Post
                          Correct me if I'm wrong, but two 2s 5050mah lipos in parallel, wouldn't that be 10,100mah, beyond the 10k limit?
                          Ben, that will only be an issue if you are attending a NAMBA event. There is no ma limit in the IMPBA.
                          http://www.impba.net/images/fbfiles/...s-20110619.pdf
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • sundog
                            • Feb 2009
                            • 878
                            I just hope it will work on 6S - I have one I plan to use in a Genesis powering a 1450kv Leopard 4082. I use another to power a 1400kv Turnigy T600 outrunner powering a 40mm Jet Drive. This boat has eaten several Chinese 200A escs, a 150A Etti and a T180 (Amperage is crazy when the jet unloads/loads back up) but the Castle keeps on going. I'm real happy with it.
                            • Darin Jordan
                              • 8332
                              Doug
                              Trouble-makers....
                              Can't he just trim the ends of the pack off a little to make them shorter??
                              • Doug Smock
                                • 5264
                                LOL He could try.
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
