First Cat!!
  • SirBudman32
    • Aug 2011
    • 701
    First Cat!!
    Looking at getting my first Cat and just not sure which to get. I really like the looks of the Pro Boat Mystic, and the Genesis Offshore but not sure which way to go. any ideas or pros and cons on each?
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
  • snehpetsffej
    • Jan 2012
    • 30
    I just bought a genesis last week. You will need a prop,speed control, RX, and TX to be able to run the boat. The plastic prop is junk. I also recommend up grading the the motor as well. The boat is very good for the price IMO.
    • HYDROJERRY
      • Jan 2010
      • 2709
      for your first cat i recomend the PB Mystic,,, i have a Geico but there the same thing or close,, and i have a Genesis,, the Mystic will be alot more stable and comes with better electronics but if your like me i id go with the Genesis cuz of her size,, it runs pritty good with the factory electronics but cant turn like the Mystic can, mine ran fine from the factory but i changed everything cuz i just wanted it faster. if you decide on the Genesis id get it from Aztechhobbies in the uk, seams they send them with better stuff, like esc and TFL metal prop..
      • Turbo Dan-O
        • Feb 2011
        • 301
        The Apparition is also a great cat. I love mine! I would also not mind having a Genesis either.
        Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
        • Rumdog
          • 6667
          So, you want a RTR only? I'd suggest building one. AM Mean Machine.
          • Boaterguy
            • 1779
            or river cat...
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1097
              I'd 2nd the "build your own" idea, I watched both the Mystic and the Geico run over the weekend and as nice a boat they are, for a little extra time and not much more money, you could just build the exact set up you want from the start rather than go rtr only to add all the suggested upgrades to the order when you buy it. I think the experience you'll get from building would be worth the extra time, thats what I found anyway.
              "Gimmy Toyz for FUN"
              • HYDROJERRY
                • Jan 2010
                • 2709
                I went that way too, and in the process of building my first boat i got tired of waiting and just bault a RTR to play with while i was still building my first one and i would say get a RTR first, enjoy running it awhile then upgrade it or build your own that way you can still have something to play with..
                • SirBudman32
                  • Aug 2011
                  • 701
                  Thanks guys for the input, still not sure which way I will go. I love the paint on the Genesis and the size of it, But then I like that the Mystic is a RTR. Another BAD thing is that the wife likes both so no help there ether.
                  • jamespl
                    • 748
                    The genesis is easy. Get the boat with all the hardware, a decent motor ie 4074 4084 leopard or similar. I run a turnigy xk4074 2000kv on 4s. Choose the kv to suit your battery choice and get a proven esc. I run the t180, or a swordfish 200a something like that and a radio then your good to go. It will be as fast as you want without having to upgrade.
                    • millzee
                      Ozzie Bloke
                      • Nov 2010
                      • 1097
                      That makes it's easy then, just get both, you'll end up with more than one boat after a short while anyway.
                      • jamespl
                        • 748
                        My wife hates all my boats ha ha
                        • Drax21
                          • Jul 2011
                          • 1077
                          This is a good one from Astecmodels in the UK http://www.astecmodels.co.uk/catalog...oducts_id=1274
                          Carbon Fiber Genesis just the hull. They also have a few ARTR Genesis packages as well. I have the Apparition from them, really strong layers of fiberglass and good seams.
                          • Drax21
                            • Jul 2011
                            • 1077
                            They have just added this....if your adventurous http://www.astecmodels.co.uk/catalog...oducts_id=1464
                            • Boaterguy
                              • 1779
                              same length and .5 inches thinner than the fantasm, suspicious..
