New mystic 1380mm .What sould i put in there ?
  • leopard15
    • 30
    So finally this amazing hull arrived from MHZ .The problem is that i got confused searcing which setup should i use and decided to ask for your help .I saw that some have used the powerfull scorpions 5035 outrunners and others the mega leopards 5692 or 5698.Can you make any suggestions for props and motor Kv range.The ESC will be the swordfish 240 HV.
  • Diesel6401
    Memento Vivere
    • 4391
    Single drive? Me thinks a CC2028 will work nicely.
    - Diesel's Youtube
    - Diesel's Fleet
    • leopard15
      • 30
      definitely for dual motor setup
        • 7512
        Turbine......X2!
        • leopard15
          • 30
          not willing to spent a fortune sorry !!
          • leopard15
            • 30
            so !!any ideas?
            • 6BOOST
              • Sep 2011
              • 286
              What is your budget? Might help us recommend parts.
              6BOOST
              6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
              • leopard15
                • 30
                i´d prefer not to exceed 800$ -900$ for esc and motor (dual)
                • 6BOOST
                  • Sep 2011
                  • 286
                  You could easily work within that limit, if your talking pure motor and esc for $900 you could use 2x Fightercat 6 or 8s 300 amp esc's and your choice of motors is almost limitless, twin NEU 1521's, 1527's, Castle 1520's, 1717's, or even the TP power 5692's being relabeled by hobby king at the moment for $70 odd. If your meant with coolers, motor shaft adapters, wiring and connectors, well that probably rules out the neu's but most of the other motors could be done with accessories for under your budget=)
                  6BOOST
                  • LarrysDrifter
                    Big Booty Daddy
                    • 3416
                    I have 2 NIB Castle 1717's for sale for $140 each. They have 6mm shafts. I have one Octura 6 x.187 collet Ill throw in if you want the motors. If you are outside of the U.S. , I ask thay you pay for the extra shipping. Let me know.
                    • leopard15
                      • 30
                      6BOOST
                      Thank you 6BOOST a lot of info .You gave me a lot of homework .Larrydrifter unfortunately i'm out of US but i let you know when i deside .You mentioned TP 5692's ,how about leopards 5692 ?I use that motor into a falcon cat single drive 1340 kv w/ x447 8s . Lets say that i will follow the TP 5692 W/ SWORDFISH 240Ah ,what kv ,what prop and finally how many lipos
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        If your planning on using the Leo 5692 you should push more than 447 props as twin setup I think it would be safe in the high 50's if you are going to use the 240HV you might as well run 12s so the 730 kv should be perfect. Even the 3994 turnigy with 450/3 should push that hull I'm not a speed freak but I think you would be in the 120-130km/h mark
                        • Mel279
                          • Dec 2008
                          • 873
                          hi leopard15
                          Since you want a budget setup for your mystic, I would suggest getting the TP or leo 56xx with around 1300kv and powered by 6s lipo. prop would be good to start with x447's.
                          • leopard15
                            • 30
                            here is what i´ve done till now
                            • leopard15
                              • 30
                              and
