Apparition 800mm (HK) Setup Questions
  • Snowride
    • 297
    Thinking about building this over the winter as I have some parts left over and looks like this boat is rather nice for the price. How would a Tacon 1700 http://www.hobbypartz.com/96m812-3674-1700kv.html perform with a HK 180 esc in the boat? Have a bunch of Nano tech 3S 6000 Batteries I would like to use on this. Good setup? This setup runs like heck on my Spartan.
  • floatn turd
    • Oct 2011
    • 336
    Im in the same boat as you, I started a thread a little down the page called: "I just bought an Apparition who has one?" you may find some info in there.
    • Snowride
      • 297
      I saw that but did not want to hijack your thread. Regardless my questions are specific to the parts I have left over which I want to use in this build. Just need to know if this stuff will work well in this hull.
      • Make-a-Wake
        FE Rules!
        • 6057
        Single motor i'm assuming, the 3674 is a bit on the smallish side for that boat, but if its a 4 poler and you prop it correctly it should be fine. That motor is an odd kv to me..........more like a 5s motor, but you could go the 6s you're wanting to with a small prop.........like an x440/442
        • Snowride
          • 297
          Thanks for the response. Yes the motor seems a little different but I have been running it off of twin 3S 6000ma packs for a total of 6S all summer long on my Spartan without any issues whatsoever, everything is running warm at best. Pushes the Spart to almost 60mph so definitely a powerful little bugger. I will go ahead and build this in this configuration as worst case scenario would be to swap the motor and prop if I do not like the performance. I was hoping for 50+ mph with this setup but I guess we will only find out come spring when she hits the water.
