Red Loctite for flex shafts
  • G1ST
    • Dec 2010
    • 351
    Will Red Loctite 271 work well for assembling flex shafts to the stub shafts?
    It would be a .150 shaft to a 3/16" stub.
    Thanks
    Greg
  • G-UNIT
    • 971
    I use the green loctite.
    stud locker/ bearing retainer, never had one come off yet in over a year.
    Iwould not trust red.
    • G-UNIT
      • 971
      I would not trust red.
      and then if you need to remove it use a propane tourch.
      • martin
        • 2881
        Do not use 271 as this is a thread locker, you need one of the retainer ones either 603, 638 or 648. I think youll find 603 is the most commomly used one. It dosnt have quite the strength of 638 or 648 but its more than enough & because of the very small gap between flex & stub hole its better suited because of its lower viscosity. 603 is also oil tolerent the others arnt, 603 is also what OSE sells & uses on the shafts that they make as well. Having said that ive used 638 as well with no failures either.
        • G1ST
          • Dec 2010
          • 351
          Cool
          Thanks for the info.
          I'll hunt down the green.
          It's not worth risking a prop and stub.
          Greg
            Just let me chime in"no it is not worth chancing the loss of a good prop or three.I use the 638 now,apparently it is alot stronger then Aquacrafts silver solder.
