Why does a boat "spin out"...............need advice.
  • Make-a-Wake
    FE Rules!
    • 6057
    For some reason my 47" mono wants to spin out now............i have done a little prop swappin lately and some minor cog tweaking but nothing major. It never cornered real well to start with but it seems worse now. I get to a certain point in the rudder throw and there she goes! Rudder too small........too big.........?........Hmmmmmm.......
  • sailr
    • 7128
    1. COG, nose heavy
    2. Angle of Strut wrong.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • cuppa
      • 46
      Hi Make-a-Wake
      Please pardon me if you have seen this site before but here is a link to a website that has an explanation of why mono hulls 'do what they do'.http://www.fastelectrics.net/monohulls.php
      I hope this helps.
      Cheers
      Jon
      oh galar da - lle oedd i roi fy ngeiriadur Cymraeg
      • Make-a-Wake
        FE Rules!
        • 6057
        Thanks guys, just got back from a run testing a new Larger rudder to see if it helped.............nope.
        Cuppa, found this on the site you posted...........
        "When a Vee hull banks over in a turn, the rudder angle relative to the water changes, causing lift as water flows down the blade. Lifting the transom can cause the boat to spin out."
        • siberianhusky
          • Dec 2009
          • 2206
          What angle is the rudder blade at? It could be lifting the trans in the turns, try tucking it closer to the transom and see what happens.
          • Mel279
            • Dec 2008
            • 873
            Is your servo high torque?sometimes not enough torque could also cause this
            • Make-a-Wake
              FE Rules!
              • 6057
              Thanks for all the replies.
              I can try the rudder tuck, and the servo is a Traxxas 2075 with 125oz. of torque............
              • Mel279
                • Dec 2008
                • 873
                Seem that your servo don't have enough torque, no surprise it spin out. At least you need 500oz torque servo
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  500???? Where do i get one of those???????
                  • Mel279
                    • Dec 2008
                    • 873
                    this one would be good http://www.hobbyking.com/hobbyking/s...dProduct=16271
                    • Make-a-Wake
                      FE Rules!
                      • 6057
                      Originally posted by Mel279 View Post
                      Thanks, 14kg of torque is around 190oz. Dont want to upgrade just a bit, if i do it will be like this with over 270oz................
                      http://www.hobbyking.com/hobbyking/s...0_12_61g_.html
                      • Mel279
                        • Dec 2008
                        • 873
                        Is it? I've convert 15kg to oz, its 500oz not 270oz
                        • Jesse J
                          scale FE enthusiast
                          • 7818
                          Turn fins big enough? Gotta be huge in a big chalumba like that.
                          "Look good doin' it"
                          See the fleet
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            14kg is 194 oz
                            • Make-a-Wake
                              FE Rules!
                              • 6057
                              They're these: http://www.offshoreelectrics.com/pro...prod=ose-80067
