Any guys run gas here???
  • Doug Smock
    • 5264
    Originally posted by Ocean Racer View Post
    It was pretty cool how about that blue boat that couldnt keep up right.
    That was Casey cutting up for the camera. The water was REALLY rough.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Ocean Racer
      • 502
      It looked pretty rough was he driveing a SV27?
      Failure is the First step to SUCCESS
      • Doug Smock
        • 5264
        No sir, that's a Titan 40 setup for P mono. Here is another vid. Titan 29, 40 and two Tritons. http://www.rcuvideos.com/item/BV4ZFZVF9YYVKWSC
        The Caseman should have been called on that little move at the end.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Ocean Racer
          • 502
          Ya it looks like some chop
          • Ocean Racer
            • 502
            Doug
            Sence u are on the subject what is a P mono setup and the other setups
            • Bill-SOCAL
              • Nov 2007
              • 1406
              P mono refers to the NAMBA classification of Fast Electric boats. NAMBA classifies boats based on power, actually nominal voltage.
              Here they are:
              D. CLASS SPECIFICATIONS
              1. POWER SPECIFICATIONS
              a) The following motor and cell configurations will be considered official for
              electric racing in NAMBA:
              M-2: A single .05 motor with brushes, any endbell, ferrite magnets.
              Power Limits: 1-4 Ni-chemistry cells are permitted.
              N-1: Any ROAR-approved stock .05 motor as defined by current ROAR
              parameters. Power Limits: 1-6 Ni-chemistry cells are permitted.
              N-2: Any single motor, any endbell, bearings, and magnets. Power
              Limits: 7.5 Volts maximum, any chemistry. Maximum of 2 packs
              in parallel. Maximum capacity of 10,000 mAh.
              O: Any amount and/or size of motors, any endbell, bearings, and
              magnets. Power Limits: 7.6 to 10 Volts nominal, any chemistry.
              Maximum of 2 packs in parallel. Maximum capacity of 10,000
              mAh.
              P: Any amount and/or size of motors, any endbell, bearings, and
              magnets. Power Limits: 10.1 to 15 Volts nominal, any chemistry.
              mAh.
              Q :Any amount and/or size of motors, any endbell, bearings, and
              magnets. Power Limits: 15.1 to 22.5 Volts nominal, any chemistry.
              mAh.
              S: Any amount and/or size of motors, any endbell, bearings, and
              magnets. Power Limits: 22.6 to 30 Volts nominal, any chemistry.
              No limit on paralleling of packs. Maximum capacity of 12,000
              mAh.
              T: Any amount and/or size of motors, any endbell, bearings, and
              magnets. Power Limits: 30.1 to 40 Volts nominal, any chemistry.
              mAh.
              b) All of the above classes may be further divided into various hull types. For
              specifications on these hull types see Section 11. Other specialty classes may
              be added from time to time.
              Hope that helps.
              Don't get me started
              • Doug Smock
                • 5264
                Namba Shmamba
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Ocean Racer
                  • 502
                  Thank u bill
                  • Bill-SOCAL
                    • Nov 2007
                    • 1406
                    Namba Shmamba
                    Doug
                    Just answering the man's question.
                    • Doug Smock
                      • 5264
                      LOL. The truth is, I support any organization that supports Fast Electrics.
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
