does anyone have problem with this coupler?
  • Mel279
    • Dec 2008
    • 857
    hi guys
    Im having problem with the coupler as in the picture. Its a 5mm to 4.7 or 3/16. Its really good when holding a flexcable but, after loosen it, it really really hard to remove the flexcable out of it. The brass part should be in position as in the picture or the other way. Sorry for my bad english if it make some confusion. I've tried to position the brass part the other way and Im still also having difficulty removing the flexcable. Does anyone have the same problem?
    Stiletto tunnel,EPV135 (53") twin cat, CT06"Spirit of Qatar", FD 47" mono, Twin Mini Cat 23.5"
  • siberianhusky
    • Dec 2009
    • 2184
    Kendt on here had the same problem with one of those couplers, not sure what he did about it. One of the guys I run with.
    • video200
      • 837
      if thats the same as on top here http://kintecracing.com/Collets_Couplers.html you can give it a few gentle taps with something as you pull the flex and it wil come right out.
      • Mel279
        • Dec 2008
        • 857
        this is my brass insert, can you notice the different between mine and the one @kintec. But I have dremel it a bit as to the one @kintec and now is ok and video200 thanks for the link
        • osprey21
          • May 2010
          • 693
          I had the same problem with that coupler. While it gripped the flex shaft quite well, it was a PITA to remove the shaft for greasing, the insert just didn't want to let go. I finally got fed up with it and went back to an Octura.
          • detox
            • 2310
            Originally posted by Mel279 View Post
            hi guys
            [ATTACH=CONFIG]67079[/ATTACH]
            I also have the same problem with brass insert being crimped onto cable (very difficult to remove cable). Some guys say try tapping, but I ended up beating and pulling very hard to remove mine. Dam there has to be an easier way to remove...anybody have answer? I know the gas guys use this type collet alot, so thay should know.
            Here is the correct way to assemble. You have it correct in your picture also.
            • Mel279
              • Dec 2008
              • 857
              Mine now its ok, I made a modification on the insert,but need to hold with spanner on the motor's shaft side, turn and pull the flexcable. At the same time, I've also order the ETTI coupler, seem to be good.
              • detox
                • 2310
                Thats right! I twisted and pulled very hard to remove.
                • Mel279
                  • Dec 2008
                  • 857
                  did you remove it with the prop still intact? or without?
                  • longballlumber
                    • 3119
                    It sounds like you guys are over tightening the coupler. Since these are a 3 piece systems with a brass insert, if you over tighten it will mull the brass since it much softer; hence the sticking. This same issue has plagued this type of coupler for a long time. Unlike the octura style that is only 2 piece.
                    3 pieces – just snug up DON’T crank it down like a gorilla!
                    2 pieces (Octura) – you’re going to need an extra Gorilla around to tighten up that thing enough to hold.. IME
                    Later,
                    Mike
                    • video200
                      • 837
                      can be as longballlumber say that you are over tightening things. i use a 10mm rong spanner and tapp gently on it while pulling the flex and have no problem getting mine out. i lost quite a few props and flex shafts with octuras cupplers but have to date never lost a flex with the 3 part one i got from kintec.
                      • sampit
                        • Jul 2009
                        • 447
                        I got got the same problem with this coupler, can not remove my shaft to grease it, cant get acsess to the brass insert either, tryed always,might have to end up cutting it off
                        FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
                        Popeye Hydro T600 1400kv 6s1p
                        • Diegoboy
                          Administrator
                          • Mar 2007
                          • 7247
                          Later,
                          Mike
                          This is exactly the case. After using the octura ones for so long, you guys assume you have to crank down, but you don't. I only use these couplers in my FE boats and moved all my octura ones to my scale (slow) boats or the round filing cabinet.
                          • detox
                            • 2310
                            So if I just snug it down my problem will go away? No slipping under full throttle load?
                            • wetsleeves
                              • 41
                              I use the same coupler and what I do to remove the flex cable is, I get a fine flat head screw driver and insert it into one of the slots on the brass insert and slightly lift the tab (only a little bit) and the cable pulls right out.
