Pursuit motor upgrade.
  • HUNTER
    • Jul 2011
    • 12
    After two months of 5s use, oops i mean abuse, the stock motor has died. I'm going to replace it with a leopard 4074 2200KV and a t180 esc. Will this fit in the stock motor mount and i just buy a new clamp ring, or do i have to install new motor mounts?????
  • Drax21
    • Jul 2011
    • 1077
    If so, yes that would be fine as I have seen it done many times before. I replaced my stock mount when I upgraded to a KEDA 4074 but really I could of kept the standard mount.
    • jamespl
      • 748
      Or maybe a cheaper motor option would be the turnigy XK4074 2000kv. I've got one in my genesis and love it. I think it's pretty much the same as the leopard.
      • Drax21
        • Jul 2011
        • 1077
        Yes its believed Turnigy has underestimated the wattage of power their Motors have, plus its been proven that they can run on 5s too with no problems.
        I recommend a 2000 kv on 5s M445 prop (may be able to prop up!)
        • HUNTER
          • Jul 2011
          • 12
          Yeah i'm going for the 2200kv so i can go back to 4s, easier to charge batteries. Motor mount is similar to one pictured, but if i go from a 36mm diameter motor to a 40mm the rear support won't fit, if i buy a support that does fit the 40mm will it still fit inside the rails?
          • jamespl
            • 748
            Should do. My 40mm motor fitted straight in the 36mm mount no prob on my genesis, and I believe it's the same mount. I just got a 40mm mout so I could support it better.
