burned up esc
  • archuraas769
    • Jun 2010
    • 53
    burned up esc
    hey everyone, i have a sv27 with an ammo 36-88 mottor and im running two 3cell 5000mah lipo batteries, the problem is i keep burning up escs, recently i burned up a sea king 120a, befor that it was a heffi sword fish 120 a, i also have an extra water pick up on the transom thats suppose to pick up 3x as much as the stock reudder pick up, i cant figure this out someone plz help
  • maddmatt
    • 250
    Howdy, What is the kv and prop size? You are setup wrong drawing too many AMPS!!!!!
    • Boaterguy
      • 1779
      what is the kv of the motor?
      how long are you running for?
      6S is the limit of the ESC so if you are pushing 120A at 6S (at the absolute limit of the ESC), you are likely to be blowing the ESC's.
      • rc2266
        • 317
        Back off to 5s on the 120, do not go 6s on that.
        I'm married with children, you can't scare me!
        • archuraas769
          • Jun 2010
          • 53
          I'm running a 1280kv mottor with a 48.3mm prop
            There is the problem, a 48+mm prop is too much for most 36mm motors, particularly on 6S. That size prop would be more appropriate on a 40 mm motor. You are pulling too many amps for 120 amp controllers - the fact you burned up several should be a warning that you are abusing them. Amps at or above the limit and voltage at the limit are a sure way to shorten the life of any ESC.
            • archuraas769
              • Jun 2010
              • 53
              Ok, so how bout if I down sized my prop and move to a sea king 180a?
                • 6057
                Sounds to me like you're running an s230 which has the same overall pitch as an X455!!!!!!!!BIGGGGGGGGGGG!!
                You can actually use a 120a ESC with that low kv motor if you prop down to an x445 or less or an s215..........
                The T180 would be the best way to go to have a strong, cool running setup with amperage 'headroom', you may be able to spin an x447 with the T180...............but i'd try an m445.
