strange esc behavior
  • kendt
    • Jul 2011
    • 579
    I bought a Hk ss 200 amp esc. I thought since I always open and inspect them before use I would catch any flaws in assmbly. I opened it on arrival and other than the cooling block was touching the motor wires (bad) it all seemed well assembled and looked fine. I added some extra caps (low esr) and hooked it to a motor to begin programming. It doesnt seem to arm. There is no sound until after it's un hooked and sits for about 30 sec when the caps discharge it lets out one beep. otherwise it doesnt work. Has anyone ever encountered this odd behavior. Im feeling that it is likely a DOA POS!!
  • Alexgar
    • Aug 2009
    • 3701
    did you check your throttle trim maybe its not arming also that esc requires a external bec
    • kendt
      • Jul 2011
      • 579
      Yes i plugged a reciever pack in and tried reversing the throttle as well as adjusting the trim. still same results.
      • Alexgar
        • Aug 2009
        • 3701
        You did unplug the red wire correct ?
        • kendt
          • Jul 2011
          • 579
          Red wire, not sure what you mean.
          • Alexgar
            • Aug 2009
            • 3701
            nevermind these are opto, i was reading another post and mixed them up , ive run 3 of these with good result up to 120 amps sorry it sounds like you might have recieved a doa
            • carlcisneros
              • Jan 2010
              • 1237
              sounds like that has gone to the big ESC hunting grounds in the sky.
              • kendt
                • Jul 2011
                • 579
                Ya thats what i'm affraid of. Just thought it strange that it beeps every time you un plug it. Not impressed to say the least.
