I have CC1520 1y 1600kv motor, What size hull would good.
    Hi,
    Need some help.
    I have cc1520 1y 1600kv motor and know nothing about them.
    Would a cc 1520 1y 1600kv motor be good for sport running ?
    What size hull can it push efficiently and on what cells ?
    Thanks for any information.
    Lenny D
  • Make-a-Wake
    FE Rules!
    • 6057
    The 1520 is a stout motor, it can really move out a 40" or less on 6s.............
      It was in the 31"Impulse,
      Are they amp hogs ?
      • Make-a-Wake
        FE Rules!
        • 6057
        I wouldnt consider them "Amp hogs", they can put out some serious wattage........3000+ on 6s
          That would be pushing a 180a esc right ?
          Would that motor run on ok 8s ?
          • jkr
            FE Addiction
            • 582
            What are you planing to do with 8s?
            • jimi911
              • Jan 2010
              • 232
              8s is going to put you up over 47000 rpm, which the motor will take, but it wont last that long. It would also require a more powerful esc. 5s or 6s is the right setup. You going to be up around 35K rpm with 6s so you don't want too big a boat. I bet it be pretty awesome in a 36" Sprintcat from Aeromarine or a 35" DF from OSE.
              www.whittingtonracing.ca
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                Runs great on 6s in a DF33 or a Cyberstorm.
                  Ok,
                  Thanks for all the info on the motor guys.
                  I may try it in my 36"Shockwave mod on 4s2p first and than 6s and if the hull likes it.
                  I do not have any 6s packs at this time, But I do have some 3s 4500mah packs to try 6s that way.
                  I need to get a good universal motor mount for easy in and out.
