29" sprintkat - motor selection
  • oscarel
    • Dec 2009
    • 2135
    No, full potential doesn't mean hot motors and esc. Does a Pinto need a stroked 350? What advantage will you gain with running a bigger motor than needed, especially since he stated sport running?
    So back to my original statement, if you're planning on using the motor in a bigger hull later then go for it.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      I say, use a 540.
      • oscarel
        • Dec 2009
        • 2135
        Originally posted by larrysdrifter View Post
        i say, use a 540.
        lol
          • 9479
          NEU always recomends more than needed when powering a FE
          many reasons for using that motor vs something smaller... it's a no brainer!!
          one is cooler running system
          two is possible less amps being pulled... more runtime and longer lasting electronics.
          so to me that is using a motor to its full potential
          I would hate to have a 4cl or 6cl in my BMW when the V8 runs awesome all day long and I don't have to push it hard to get upto highway speeds........ etc.
          • oscarel
            • Dec 2009
            • 2135
            I'm sure a v10 or v12 would be even more awesome, but is it necessary?
            Sprintkat, I'm just north of you in Mckinney. If you want to see what I have let me know.
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              lol
              Had to think about your response, but I meant a 540 size electric motor, not a BBC in a Pinto...although a Chevy is the correct way to power a Ford!
              • oscarel
                • Dec 2009
                • 2135
                I have some friends that actually did it. Have another that put a Dodge 440 in a Chevy an old truck as well.
                  • 9479
                  • Jeff Wohlt
                    • 2716
                    Yep...it was the motor that sucks...not that ESC. That motor has a history.
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                      • 9479
                      WOW???
                      not sure if your really reading what's posted or just typing???
                      so are you now going to say a 650HP KR Mustang should not be built??
                      not something you would need doing 55mph but nice to know its at your right foot anytime you wana smash that pedal
                      • oscarel
                        • Dec 2009
                        • 2135
                        Yep, I'm reading. Are you?
                        Originally posted by sprintkat View Post
                        ok - sport
                        Besides saying mine is bigger than yours, what really does it buy to go bigger? I'm answering the OP's questions based on experience not what I "think" would be best. Would it not be better to put the extra money into say batteries than waste it in a motor that is way more than necessary?
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3278
                          Use the 36-75-1 Arc motor on 6s.
                          In a hull that small, you will have your hands full with this motor on 6s. You wont need to run 2p. Use two 3s 5000mah 40-50c packs in series. No need for a 40mm motor in that boat. Use a 180 amp speedo and start with an X442. There is your stupid fast, reliable set up in your small hull. Itll be in the 60's with no problem. By the way, you dont need to start multiple threads asking the same questions. Ask em all here.
                          Id go with what this guy said. I dont own a SprintCat, but, I think itll work. Plus, I do know Arc motors rock. Way better than a Leopard.
                          • oscarel
                            • Dec 2009
                            • 2135
                            And I also agree. I own and have tried and it's a waste. Or better yet, why not go all out and put a 2028 in it!!
                            • oscarel
                              • Dec 2009
                              • 2135
                              Are you looking to get one directly from Aeromarine? If so, I believe there's two layups, regular and electric, with electric being lighter. If you're running on a pond with little/no wind this will not be an issue (electric layup) but if you are planning on "insane" speeds as you quoted the regular with maybe carbon added may be needed. Also make sure to get the .21 rudder and don't shorten it.
                              • LarrysDrifter
                                Big Booty Daddy
                                • May 2010
                                • 3278
                                Whats a waste? The 40mm motor in a small boat? I think this thread bacame a topic about our own discussion, and not helping the new guy.
