29" sprintkat - motor selection
  • Diesel6401
    replied
    Originally posted by Rumdog View Post
    I ran a CC/Neu 1518 which is 1800kv, on 4 and 5s. More than enough power for that hull.
    +1 on that
    Leave a comment:
  • Rumdog
    replied
    Leave a comment:
  • Diesel6401
    replied
    Originally posted by sprintkat View Post
    was running 6s w/kb45 8l w/seaking 180-300 max esc .octura x440 3 blade. burnt up 2 seaking esc's
    was looking for a new setup, since chineese equipment seem to suck.
    i got 3000 mah 4000mah and 5000mah all 30 c burst have 2-5000mah w/40c burst and 2 evo25 w/50c burst
    i can run 3s or 6s. whats good motor and esc setup that is dependable
    The seaking esc's are AWESOME especially the 180s, the problem is def not the esc's it your setup. Your setup needs a lot of work, if your running a kb45 (which are terrible amp sucking motors to begine with) on 6s that's the issue. If your runing the 8L which is 2300kv on 6s, that's a WHOLE lot of unloaded rpm's and add the fact the KB series motors are typically inefficient and that is what is leading to your esc failures. Until you change your setup, your gonna keep blowing esc's. There is not a motor that is gonna satisfy your needs for 3s and 6s operation, it's either one or the other and running 3s on that sprintcat may not be the best either. I would stick with 4s or 5s setup on that sprintcat. Look at the Leopard 4074 range of motors in the 1600-1800 range on 4s or 5s or 1900-2200 range on 4s... JMHO
    Leave a comment:
  • sprintkat
    replied
    i live in waxahachie texas. was watching oval racing up in carrolton texas that a local hobby shop puts on every 2nd sunday of the month
    oval and sport racing
    Leave a comment:
    replied
    What voltage do you want to run? The answers to your questions will depend largely on the voltage - 2S, 4S, 6S. Also, what type of running - oval racing, SAW, sport?
    Where in Texas do you live?
    Leave a comment:
  • sprintkat
    started a topic 29" sprintkat - motor selection
    have a 29" sprintkat what motor should i use to get this hull to go at least 60 mph ?
    would the leopard 4082 work. also need a reasonabley priced ESC
    want to run 5000 mah 30c burst lipo battery
