Flex shaft and Collet advice Needed !!!
  • gsbuickman
    • Jul 2011
    • 1500
    Hello everybody,
    I am getting ready to place a parts order for my 2 builds. Before I do, I would like some input please.
    I am converting my Miss Budweiser to electric, It originally had a Dynamite .15 motor that turned 30 mph runs. the solid drive shaft is 8 1/2" x 1/8" (or 0.125) w/ 3/16" OD stuffing tube. The prop angle is non adjustable.
    I was thinking of using this flex shaft, from here at OSE
    Product ID: oct-oc098L-24c
    Octura .098 cable system
    In Stock: 8
    Octura .098 flex cable with 1/8" prop shaft, drive dog, bullet nut and teflon liner.
    We offer these unassembled or assembled.
    Requires: 3/16 OD K&S brass tubing for stuffing tube when used with the Teflon liner.
    I am unsure of the length of this shaft, and the motor limit for it as well.
    I may be able to put a coupler on the solid druve shaft, but I prefer flex shafts.
    If this wont be a feasible route, I can glass in a new tube and go with a ul-1 tube, shaft, coupler and adjustable strut ?.
    I already removed the aluminum motor mounting blocks, so I can use an adjustable motor mount ?.
    Any suggestions would be appreciated and Thanks
  • JIM MARCUM
    • Jun 2011
    • 775
    I've converted a 46" gas hydro & 56" Gas Segad to electric. Both had 1/4" flex drives so that part was EZ. From your pics, it looks like the stock 1/8 straight drive shaft would be OK if you put a 1/8" U joint it, run a short 1/8 shaft to a clevis with 1/8" exit end on your motor. A better option is to remove the fiberglass shaft support on the bottom of the hull & install a 3/16 flex drive with a 3/16" strut or stinger drive. I prefer stingers. Adjustable prop shafts beat non-adjustable every time. JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
