I just bought my first tunnel hull 'cobra' and am looking for a picture of how to run the cooling system with the OS outboard setup? There are 3 nipples on the outboard? I just don't want to burn up anything. Thanks Jason
Outboard water cooling questions???
Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!Tags: None
May I please ask what is the purpose of this blue line and how it works?
Thanks
RobertAttached FilesDJI Drone Advanced Pilot
Canada
Hey Robert, the "blue" line is the oil line...the blue color is just residue from the flex grease that gets thrown in there. I pull that line off from the upper nipple and simply fill the line with 3 n 1 oil before each run to keep the flex lubed ( I also grease the flex itself ). You can also use Marvel Mystery oil and STP like Brian Buaas uses...Last edited by HOTWATER; 11-28-2011, 08:44 PM.
I see.... It make sense now...
One more quastion. I see you have very nicely done conversion adapter....
Where did you get it from? What prop are you spinning with this Ul-1 motor?
Chrres
Robert
Originally posted by HOTWATER View PostHey Robert, the "blue" line is the oil line...the blue color is just residue from the flex grease that gets thrown in there. I pull that line off from the upper nipple and simply fill the line with 3 n 1 oil before each run to keep the flex lubed ( I also grease the flex itself ). You can also use Marvel Mystery oil and STP like Brian Buaas uses...DJI Drone Advanced Pilot
Canada
That is a conversion made by Kris Flynn...he is on this board. Not sure if he is making any more of them, but you could ask. BTW, his O/B flex's that he also makes are second to none...very well made!
That is what I was thinking....
I have one kit on the go from Kris with motor coolet and flexshaft....
Takes forever to get staff here in Canada from Australia....
Cheers
Robert
PS
What prop are you spinnig?
Originally posted by HOTWATER View PostThat is a conversion made by Kris Flynn...he is on this board. Not sure if he is making any more of them, but you could ask. BTW, his O/B flex's that he also makes are second to none...very well made!DJI Drone Advanced Pilot
Canada
Cheers
Robert
PS
I am currently using a modded 42X55 prop.........
