Easy way to cut PVC for boat stands
  • sigelitest
    • Jul 2011
    • 422
    An easy way to cut PVC for boat stands
    Tubing cutter with a couple of passes will clean cut PVC with no mess
    + u can do it Quietly while spending quality time watching TV with your significant other.
  • egneg
    • 4759
    This works better imo.
    IMPBA 20481S D-12
    • Diegoboy
      • Mar 2007
      • 7443
      You can get an inexpensive one HERE
      • JackBlack26
        • May 2007
        • 904
        Diego, best advice ever. I have the Klein version cause I'm an electrician, but I couldn't imagine cutting PVC with a tubing cutter. I hate those things.
        • sailr
          • 7128
          yep, that dedicated cutter for pvc works absolutely great. I agree, a tubing cutter would be a pita!
          Mini Cat Racing USA
          www.minicatracingusa.com
          • steveo
            • 1595
            i find a good karate chop works best for me- hey jackblack 26 are your boat stands grey and did you use sch 40 /80 ?
            • sigelitest
              • Jul 2011
              • 422
              The tubing/copper pipe cutter goes up to 1.5 inch dia only takes about 3 twists and it is cut. 11 bucks . I have used the PVC cutter also. About the same to me.
              Use what u like. Just saying better than plastic shavings everywhere from a saw.
              • carlcisneros
                • Jan 2010
                • 1237
                I just use my band saw when I make up a boat stand.
                • 6BOOST
                  • Sep 2011
                  • 286
                  Drop saw here, dust/shavings don't bother me, that's what the workshop is for:P
                  6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
                  • JackBlack26
                    • May 2007
                    • 904
                    No, I use whit irrigation pipe. Not a fan of gray PVC since I have to see it so often, lol.
                    • photohoward1
                      • 1781
                      Why not just a small hand saw? It's not rocket science.
                      • Boaterguy
                        • 1779
                        theyre complaining about the cleanup, guess these old guys can't bend over with the dustpan.
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          Hand saw can take a minute or more to cut, the above cutters cuts clean through in seconds.
                          Who's bending over these days?
                          Isn't technology awesome?
                          • Diegoboy
                            • Mar 2007
                            • 7443
                            One handed (left handed even)
                            • Boaterguy
                              • 1779
                              that is a pretty clean cut.
                              yay another leftie!
