Originally posted by Mattwarner
View Post
anyone build fightercat cheetah 34" yet?
This topic is closed.
Looks great. Not too bad to tape down either...
Kevlar lining from the factory? Nice to see someone doing this.
He we go, this is a 4074 Leopard looking lost ,you could fit motors in as big as you want plenty of room
the kevlar has been linned when the hull was in two halves, so the complete bottom side of hull all the way up the sponsons is kevlar
and nicely done too.
the 78mm mono stingers supplied look to big to fit the transoms so at a standstill now with twin setup, might go for a single setup instead
Going to be painted Monday Lumo Orange and metalic blackAttached FilesFC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1p
I guess in local club racing one could possibly run in "P" with the approval of others but according to NAMBA the hull is too long. they will have to run in Q against the 37 in Sprintcats - Good luck.. I dont understand why Ben didnt "Design" the boat with racing classes in mind. Just .5 inch shorter you've got a hull that could possibly dominate the open "p" class."If you can't win - Wreck someone who can!"
Why does no one want to show the bottom of the hull? hmmm"A quick temper will make a fool of you soon enough."
Its an apparition, which incidentally is wider than a genesis so the Cheetah is going to look even broader when up against a genesis! Sam i think twin 3126's are going to be too small having seen these pics, maybe you should get another 3740 and run twins, your 1800kv should work well on a 5S.
Did it come with the stingers or did you order then seperately? i need some stingers for my Apparition but guess if they dont fit the Cheetah they wont fit an APP.
What is the width? & Please spost a pic of the bottom."A quick temper will make a fool of you soon enough."
