Problem!!!!
  • Eodman
    • 1285
    Problem!!!!
    Last summer I picked up a H & M Mono off Ebay nice boat !!!! Now the problem ... now that spring is just around the corner I was getting things ready to go and I screwed up! While watching TV I hook up the power leads wrong & smoked the ESC now I have to replace the ESC. It is powered by a NEU 1515.1D --- will a Hydra 120 handle this motor?
    There are no markings or labels on the esc so I need !
    We did it with a Bang!
    Cats Are Where It's At!
  • TeamFubarRacing
    • 45
    NO...
    Ron
    TeamFubarRacing, Winter Park, FL
    • txboatpilot
      • 1805
      Get a Hydra 240 or a MGM 22418......Or a Schulze fut18.149............
      Here is a link to buy MGM and Schulze....
      ICARE, accessories, scale sailplane, glider, R/C, electric model airplanes, electric accessories, Hacker, Schulze, Jeti, Mega, Sanyo, SP400, brushless motors, batteries, chargers, propellers, spinners, gearboxes, motor controller
      If you want to go cheap but it will work, GX-200A esc...
      Link...http://www.himodel.com/electric/HiMo...00A-OPTO.html#
      Nothing like keeping you lipos warm and your prop wet!!
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        re :
        Hmmm.. $ 62.50 for a 200 amp speed control sounds pretty interesting; have you [or anyone] used one ? With what results ?
        • Eyekandyboats
          • 1935
          the 1D are amp hogs because of there winding. and the early hydras had some problems.
          hydra 240 if you wanted a castle esc.
          that GX200A might work as well
          EYEKANDYGRAPHICS
          www.rclipos.com
          • txboatpilot
            • 1805
            I have used a GX-200 on a Hacker 8XL in a 30" Cat... The esc works smooth, runs cool, but you do have to waterproof it yourself and add cooling! (water or sm. fan).. I have 2 more ordered, and a local friend has ordered 3-4.....
            • Darin Jordan
              • 9446
              Originally posted by TeamFubarRacing View Post
              NO...
              Ron
              Hmmmm....
              I've been racing 1515 1D motors in all of my O-boats (Sport Hydro and Mono) two seasons ago, and in all my N2 boats for all of last season, including racing at the 2007 "Nats", using Castle Barracuda 125 ESCs (both older and newer designs) and haven't had a single problem... They didn't even get hot...
              Must just be lucky I guess...
              I would recommend something bigger just for the additional buffer of safety, however, if you are having to buy something anyhow...
              Darin E. Jordan - Renton, WA
              • TeamFubarRacing
                • 45
                Darin,
                you can hmmmmmmmmm till the cows come home...
                did the man say 2s in his H&M mono?
                i got a feeling he was talking about a 4s set-up...
                but i bow to the man who knows all and see's all from the great N/W :
                Ron
                • txboatpilot
                  • 1805
                  Darin,
                  Ron
                  I have never heard of anyone running the 1515/1D on 4S???
                  I am I missing something... The motor is around 4100KV or so right? That would put you at 65000 unloaded RPM???
                  My understanding is this is "THE" 2S motor to have??
                  • TeamFubarRacing
                    • 45
                    4100 kv
                    8-18v
                    200 max amps
                    85% eff.
                    Ray Fuller, Doug Smock, just to name two held the I.M.P.B.A. P-Mono 1/16th mile record running 1515 1D's in mono's on 4s voltage...
                    Mike Pags recently spoke of trying one in an oval set-up P-Mono as well...
                    in this day and time folks will try anything...
                    Ron
                    • txboatpilot
                      • 1805
                      4100 kv
                      8-18v
                      200 max amps
                      85% eff.
                      Ron
                      Cool deal, I did not know that.. Learn something new everyday!
                      This seems to be the EXTREME side of running the 1515/1D..
                      What esc's did Ray or Doug use??
                      Man, I run a 1515/1.5D in a Matrix rigger on 4S and it FLYS!!! I cant even imagine it with a 1D on 4S!!
                      • TeamFubarRacing
                        • 45
                        both ran Schulze 40.160's
                        Ron
                        • Darin Jordan
                          • 9446
                          Ron
                          If Mr. Eodman was talking 4S, then I appologize... I only assumed he was talking about a reasonable 2S setup... not a 4S hand grenade SAW boat...
                          And for the record... I have never even considered that I "know all" and would love to figure out how to go about NOT coming off that way... I do KNOW some things, however... and I do KNOW that a 1515 1D will work very well using a B125 ESC on 2S in a 27"-ish Mono or Sport Hydro...
                          Again, if Mr. Eodman was talking 4S... then my comment would change... I'll make sure to understand that next time...
                            • 7512
                            It would appear that Mr. Eodman left out one fairly important piece of information, the voltage of the packs he is using. Until we know that, everyone is right
                            • Darin Jordan
                              • 9446
                              I like it...
