what size delta force hull?
  • ironjaws
    • Jul 2011
    • 286
    Trying to get an opinion on what hull length would be best for the 4074 leopard 2200kv motor and 200 swordfish esc.? Running 4s2p
  • Basstronics
    • 2384
    I wouldnt try putting it in the 29", probably would be pressed for room. I squeezed one into a 25" clone hull, never run it though.
    Im building a 33" Pursuit, which is a kinda clone. Thats got a 4074 in it.
    So I would say the 33" versions. Maybe the 35" also... Nothing larger.
    • Rumdog
      • 6667
      I'd peronally run it in the 29. The 33 is a right at the max size for that motor and you'll nedd to keep prop size in check.
      • Diesel6401
        Memento Vivere
        • 4391
        Leopard 4074 2200kv and a seaking 180. Prop was a m645 https://www.youtube.com/watch?v=Az0z...e_gdata_player
        With that being said the motor is at its limit. I am thinking about changing to a 4082 2200 or something in the 4074 size but lower kv. The motor u have can work in a 33" hull, but would be better in a df29 like rummy mentioned. If you would go with a 4074 size, I would recommend a lower kv in the df33 hulls. jmho
        Sent from my T-Mobile G2 using Tapatalk
        - Diesel's Youtube
        - Diesel's Fleet
        • Alexgar
          • Aug 2009
          • 3701
          Cc1515 in a df29 a very similar motor 55mph+ on 4s1p 5000 50c
          • Make-a-Wake
            FE Rules!
            • 6057
            My 32" Pursuit Vee runs upper 40's and cool with a Leopard 2150kv on 4s spinnin' an x442........................
            • frenky
              • Aug 2009
              • 2
              What about the 37" FSR-21 mk2 hull~~~~
              We run it by NITRO21 , the speed is not slower then 33-35", but more stable~~~
                I normally would not recommend using that much power in such a small hull, but after seeing several DF26 boats run so well I'd have to deviate. For some reason, the small hull handles power better than the 29. I watched one make repeated passes in the high 70s in LA last month. One club member has a 1515/1Y in his and it handles rough water far better than I would have imagined...a very versatile hull.
                The Leopard 4072 is about equivalent to the Neu 1515, slightly less power actually and it runs hotter. Switching them back and forth in the same boat/setup demonstrates which runs better.
                • Scott T
                  • 625
                  I'd agree with Jay, I've seen DF26s (and the clones) handle far better than I would expect (I'm looking at you JWT!). However, in this case I would go for the Cyber Storm. A great hull for that power source.
                  Scott Tapsall
                  Pine Rivers Model Powerboat Club - Facebook Page
                  My Gallery
                  • dana
                    • Mar 2010
                    • 3660
                    hmmmm… thats pretty cool. i was just thinking about a winter build too….
