5.5 Bullet Connectors Hole diameter??
  • Drax21
    • Jul 2011
    • 1077
    This may be one of the most unusual questions asked on here but here goes. I have bought some bullet connectors (5.5mm) off ebay. They have holes either side as I want to make a parallel connector out of them.
    Can any one tell me what the diameter of the hole is going through each connector?????
    or just tell me in (mm) what size diameter this brass pipe is??
    Thanks
  • egneg
    • 4759
    The size of the tubing is 3/32" or 2.38mm.
    IMPBA 20481S D-12
    • desmobob
      • Sep 2011
      • 172
      3/32" is .0938" or 2.381mm.
      Take it easy,
      desmobob
      • Drax21
        • Jul 2011
        • 1077
        Thanks now I can get my parallel connectors sorted.
        • circus162
          • 104
          I like your connectors. What are you using as insulation?
          Thanks,
          Rich
          • egneg
            • 4759
            Thanks,
            Rich
            Here is the thread the picture came from.
            http://forums.offshoreelectrics.com/...ors&highlight=
            IMPBA 20481S D-12
            • m4a1usr
              Fast Electric Addict
              • 2036
              If you can find a solid conductor it would conduct amperage better than 3/16" tubing. The K&S tubing has a wall thickness of .010 and has the cross sectional capability of delivering current comparable to 12ga wire. Dont believe me? Here you go.
              Use a solid piece of material, like a rod. Tubing has a very small cross sectional area and while it is easy to use because we have that material it does not conduct as well as a solid conductor does. Now if your happy with a 60 to 80 amp conductor then use 12 ga wire or 3/16 brass tubing. But if you are sure your drawing more,... then use whats right. Greater conductivity means lower connector temps.
              John
              Change is the one Constant
              • Drax21
                • Jul 2011
                • 1077
                I have got a solid brass pole to go through the middle. Just typed in 3/32 brass. I will be using silver solder too so melting will not be a prob. Thanks for the advice John
                • egneg
                  • 4759
                  John
                  Apples and oranges. The tubing really doesn't carry the load, it is only used to hold the pieces together until they are soldered. There is more surface contact between the connectors than there is with the tubing.
                  IMPBA 20481S D-12
                  • Drax21
                    • Jul 2011
                    • 1077
                    [ATTACH=CONFIG]62964[/ATTACH]
                    True
                    • Drax21
                      • Jul 2011
                      • 1077
                      Wouldn't silver be the best instead of using brass. Best conductor anyway.
