brushless ?
  • SweetZ28
    • 1535
    brushless ?
    Hi guy's i have a ? maybe you guy's can help me out here...
    I have the proboat Apache 24 and i re did the drive line to the flex cable style... Now here is the BIG ? I have a novak brushless system with a super stock motor and it supposed to be exactly like a brushed 19 turn spec motor spec wise... Could i run it in the 24" apache?
    and if i go with the carbon fiber blades should i use the smallest one available ..or will it be not small enough..? Lastly how fast do you think it will make my boat go on a 7.2V set up?
    Thanks
    WWW.PPRSLOTS.COM
  • SJFE
    • 4867
    If motor/esc is = to a 19-t system it will be safe to use. The stock prop may be just fine. That stock motor is more than likley 27 turns. Depending on prop and weight variables you are looking @ maybe 5mph. If you have everthing on hand I say what the heck... Go for it. Post in the build section. I wana see hiw it works out. For the record I like that hull .
    • SweetZ28
      • 1535
      Humm I have to see what I am going to do for sure on this.
      Thanks for the input
      WWW.PPRSLOTS.COM
