4mm to.... 3/16 dog forks?
  • iamandrew
    • 574
    Hi everyone.
    Ive got some drive dogs, 4mm ones, and 3/16 ones, however i need to find out whether or not you can buy the 4mm drive dogs, with the 3/16 size ..forks? to hold the prop?
    Ive got a shim for the 642 on the 4mm shaft, but its got a bit of play in it because the prop has bigger spacing than the drive dog.
    any help!? thanks
  • canjohn
    • Aug 2011
    • 17
    drive-dogs
    Originally posted by iamandrew View Post
    Hi everyone.
    any help!? thanks
    have you tried the graupner 4mm-3\16 adapter?
    • iamandrew
      • 574
      Yeah i had a quick look but i dont think i could even modify it.
      im sure someone here will just say "Oh upgrade the entire drive shaft to 3/16" but yeah..
      I dont have tools to make one
      Im starting to think i might just have to use a 3/16 drive dog with a shim, with a hole cut into it for the screw to go through... not sure if its a good solution though
      • iamandrew
        • 574
        anyone else got any ideas without replacing the entire drive shaft?
        • Boaterguy
          • 1760
          i've done a shim for 4 mm to 3/16, i can send it to you if you want it, I don't use it anymore.
          • Rumdog
            • 6453
            • Boaterguy
              • 1760
              he doesn't want to.
              • iamandrew
                • 574
                Ive already got a shim that slides over the 4mm drive to get the 3/16 prop to fit well, but its the fork bit at the front of the prop.
                Say if you hold the drive dog still, you can rotate the prop 1 or 2 mm
                I found that after running it, it was starting to show a bit of wear on the shim.
                • Rumdog
                  • 6453
                  Lose the band-aid idea and just swap it out for the apropriate gear.
                  • Boaterguy
                    • 1760
                    this is definitely the best option, and more reliable.
                    you may end up spending just as much time and money trying to fix it than swapping it.
                    • siberianhusky
                      • Dec 2009
                      • 2184
                      Use a shim and a 3/16 drive dog with a longer grub screw, drill a hole in the shim so the grubscrew locks onto the shaft itself through the shim.
                      It's a band aid set up but it might work.
                      • Boaterguy
                        • 1760
                        that's the shim i was gonna send him, it also extends to cover the prop too.
                        • siberianhusky
                          • Dec 2009
                          • 2184
                          Cool, didn't know they were long enough to do that, thought it might only do the width of a prop.
                          Did you buy it or make it, if made what diameter tubing did you use?
                          • Boaterguy
                            • 1760
                            I had the tube lying around, it was a year ago i made it so i don't remember, take the 4mm shaft to the LHS and find some tubing that slides over it, the OD should be 3/16
                            PM me your addy and I'll shove it in an envelope.
                            • siberianhusky
                              • Dec 2009
                              • 2184
                              LOL I don't have anything that runs 4mm, just something I'd make up and have in the tool box.
                              Thanks though.
