Taking Apart Proboat 1500 Motor NEED HELP
  • monojeff
    • Nov 2010
    • 2728
    How do I go about taking apart the motor I am pretty sure I need to replace the bearings on a motor and have no idea how to get to them.
    PLEASE HELP!!
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
  • Alexgar
    • Aug 2009
    • 3701
    I made a handle out of steel and twisted out with the screws on the frt endbell
    • monojeff
      • Nov 2010
      • 2728
      What did you hold the motor with?
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • Alexgar
        • Aug 2009
        • 3701
        An old piece of rubber and a vice
        • monojeff
          • Nov 2010
          • 2728
          Awesome I will give it a try tomorrow.
          What did you take it apart for?
          Did you replace the bearing if so which kind did you use??
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • monojeff
            • Nov 2010
            • 2728
            Alex worked like a charm bolted the motor to a motor mount piece I have and twisted and off came the front piece.
            I don't know that it was the bearings that are the issue on the motor.
            The piece the shaft is connected to the armature?
            Has dents/divots in it and I think it possibly rubs against the magnets which is causing a strange noise.
            Does this mean it is bad or worn out I am pretty sure the inside should be smooth and completely circular?
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
