steeped mono v deep vee
  • sampit
    • Jul 2009
    • 466
    Hi,
    Looking at buying a new mono hull for 50 mph + spend more than two weeks trying to make a decision losing sleep thinking about it!
    i have bought to many boats in the past hopefully can get it right this time with a bit of help
    short listed
    either a DF Cyberstorm or an Etti Exiga
    what's is the main difference between a stepped hull and vee hull?
    I will be using an Leopard 4074 1400kv on 6s
    running conditions will be a bit choppy as winter is on us, the exiga has a flood chamber so will save me the hasle with flip overs
    not to sure what happens when a vee hull flips over do the self right due the weight distrbution
    not for any competition just fun
    thanks in advance
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • martin
    • 2881
    The v hull will be more stable in the rough than the stepped, Also v hulls of this size wont self right with weight distribution. You would need to build a flood chamber in to get self righting. You can get mini boats to self right with weight distribution + an offset air chamber in the hatch but because of the weight of everything in larger boats that virtually immposible to do without a flood chamber. Most use a rescue dinghy or an rc rescue boat. You could look at the Toysport hulls if you want a larger hull that selfrights as they have a chamber already fitted. But their expensive hulls.
    • sampit
      • Jul 2009
      • 466
      Thanks Martin
      is the Cyberstorm a better hull than a DF 29 for a 6s setup?
        IMO a 29" mono hull is too small for 6S and 50+ mph speeds unless you run only on very flat water. The 33" DF hull will be better all around.
        • sampit
          • Jul 2009
          • 466
          DF Cyberstorm it is then!
          thanks fluid
          could i use a FC 3640 1760KV outrunner, i have one spare could be fun, or should i stick with the Leopard 4074 1400kv
          • martin
            • 2881
            1760kv outrunner would be better suited to 5s, Leopard is fine on 6s. Martin.
