Need help for Schulze 40-160 ESC
    I got a used boat with a 12s lipo setup, the boat came with the Schulze Future 40.160 ESC . I can tell that a separate receiver pack was used. I am confused however since the previous owner/builder did not take out the thin red (pos) wire from the ESC to receiver wire lead. I always used BEC, this is first time using receiver pack and I remember reading here at the Forum that I need to pull out the red thin wire out before connecting to the reveiver. Anyone with answer would be greatly appreciated.
    Tim
  • David Kingston
    • 155
    Leave all receiver leads in the controller and plug it into receiver.
    Power up transmitter
    Power up receiver
    Plug in main battery to Esc and go boating.
    Schulze should set itself to your transmitter
    Hope that helps.
    Removal of the red lead is not required. I dont think the Esc works if it is removed.
    Dave
      Dave is right. The OP's confusion is because he has only used ESCs with a BEC. Old skool ESCs did not have a BEC, the 40-160 being one of those.
        Thanks ,you guys are great help! I did it, wow, first time seeing this made me a bit nervous. It started right up, will post when I finish restoring the boat, UPS did a number on her, bent the rudder, made a lot of gel coat hairline cracks. Oh, BTW, it is a DF 45 with a Neu 2030, 730kv motor. ( exact kv escapes my memory at the moment) runs on 12s. I almost wish I didn't get this boat, too much for me to deal with. lol... May need? ask alot more quwstions down the road! Thanks, guys!
          Actually that motor will run on 10S fine too. Some guys run 12S on the 40-160 without problems but that is actually slightly above its stated maximum voltage rating. The Kv is 725 and that motor will spin a lot of prop on 10S.
            Thanks, I was thinking 12s may be a bit too much. 10s sounds just about right. It came with a X457 prop,( I think) hope that works.
            • Punisher 67
              Ignore list member #67
              • 1616
              Here is a video of a DF45 with a Neu 2230/1Y on 10 cell packs just to give you an idea what they go like . you don't want to go 12 cell right off the bat way to scary . actually why not try 8 cell packs for your first run just to get a feel for your new toy .
                It will safely swing a lot more prop than that on 10S. The extra voltage needs a smaller prop. You should be good with an x462 to x465, but start with the x457.
                • Punisher 67
                  • 1616
                  Yes I agree with Jay being extreemly familiar with this hull , I have even run mine with a X455/3 for more run time and it still sails past 50mph with that prop . I use a X460/3 and get very close to 65mph on 10 cells . Never tried 12 yet
                    • 7512
                    Originally posted by Punisher 67 View Post
                    Never tried 12 yet
                    Chicken.
                    • Punisher 67
                      • 1616
                      Chicken.
                      Cautious.....
                      As cool as it is to see a lipo fire they are never any fun when you are the one supplying the entertainment........
                        Thanks to you all, I am not on you guy's level, in fact I am humbled by this knowledge and my admiration goes higher by the day for you guys! so I will really start with a lot of caution. Man, that red Sniper looks so good on the water. I have one question for now, the boat , as I said before came with 12s set up. It was using 2 banks of 12s . Parallel wiring so total voltage is 12s. It uses four 6s batteries. So there is 10,000 mah of capacity, battery being 5000mah each. I find the weight on the batteries is tremendous, is that normal for this hull? Like I said, I am really confused. On the other hand I won't be running 12s so weight should go down, but my curiosity is killing me. I don't want to offend anyone, but maybe the setup from the getgo was too extreme?
                        Again, thanks to you all!
                          My 10S boats weigh between 17 and 20 pounds ready to run - weight can be your friend especially in rougher water.
                            Thanks! I feel better already!
                            • Anbjorn
                              • Apr 2009
                              • 255
                              I don't think you should worry about the weight. Fluid is correct, weight can be your friend.
                              I run my Sniper on 12S2P with four 5500mAh packs. The hull is also heavily reinforced. I don't know the weight of the boat RTR, but it is quite heavy. The big Schulze 40.300 also weighs alot.
                              Start off with the X457 and learn to feel the boat from there. Be carefull when accellerating, set the radio to slow if you can. Hard accelleration will cause huge amp spikes. Make sure your caps are good. More caps would be even better.
                              With the correct CG and prop depth I would estimate ampdraw with the 725kv motor on 12S with a Prather 260 to be close to 200amps a full speed. Atleast double that at hard accelleration.
                              I have yet to run mine at perfect conditions, but I find it very hard to control the boat when passing 140km/h (87mph) on the GPS with the current setup.
                              It would be fun to see pictures of your boat.
                              Anbjørn
