Replacement Motors
  • PvtSpoon
    • Aug 2011
    • 83
    Replacement Motors
    What a good replacement for a 2848 2604kv motor as one of the motors in my twin brushless cat has died, im running and 90A esc and on 3s 4000mh as there's no room in the boat for 4s
    ive looked the
    Ammo 28-56-3200Kv
    Motor Diameter: 1.1" (28mm)
    Motor Length: 2.2" (56mm)
    Shaft Diameter: .126" (3.2mm)
    Shaft Length: .591" (15mm)
    kV Rating: 3200 rpm/V
    Weight: 5.9oz (166g)
    Input Voltage: 7.4-14.8V
    Max. Constant Current: 45A
    Max. Surge Current: 75A
    Max. Constant Watts: 666W
    No Load Current: 2.7A
    Or
    Red Leopard LBP2860
    any ideas or thoughts welcome
  • JPriami
    N4FOX
    • 1711
    What cat hull is it?
    • PvtSpoon
      • Aug 2011
      • 83
      36" RC EP Fiberglass FRP Twin Power Catamaran a-RTR Racing Boat
      • Make-a-Wake
        FE Rules!
        • 6057
        I'd run a couple of the 2860 Leopard 2910kv 4 pole motors if it were mine......................
        • Flying Scotsman
          Fast Electric Adict!
          • 5195
          I would replace both with Neu motors but to be very honest, I would look at ditching that hull and that you should search for a decent cat hull from many posts, used or new on this forum and build your dream boat.
          Douggie
