Genesis on 10S not fast enough
  • Mtwinste
    • Jul 2011
    • 140
    Great points. I'll do it. The rudder is sharp just had to file down some dings.
      Also,
      Not shore if it was done,Yet.
      But sanding the bottom of the hull adds air bubbles and less drag to,
      I used #400 wet sand paper, From the stern sand forward 8", Towards the bow.
      It works some.
      • Mtwinste
        • Jul 2011
        • 140
        Lenny i bought it used on here and the dude before me leveled and sanded the bottom, i might do it a little more just to see...
        • Mtwinste
          • Jul 2011
          • 140
          Ran it yesterday with two new TP 10s 65c batteries. Melted both the batteries down. Motor and ESC heat were fine. That's too bad. Wonder why the batteries puffed and everything else was fine?
            • 7512
            #35
            Probably ran the voltage to low..thats the only time I have ever seen batteries puff.
              #36
              How many break-in cycles did you do with the packs before running them at full amp draw? ThunderPower recommends several cycles at 3C-5C prior to full power operation. What was the pack temperature when you taped up the hull? Cold packs and high amp draws equals damage.
              • Gary
                • Jan 2009
                • 1104
                #37
                Very true with the battery temperatures. I preheat my batteries EVERY time on run. Actually I have a timer that turns on the heater box at 5am in the morning and shuts off at 5:45 when I walk out the door. If it is really cold I then transfer to the car lighter and plug the heater box in on the way to the lake. Cold batteries, lipo's, ALWAYS run slower than warm Lipos. If its a cold time of year, try it, you will be pretty surprised!
                H&M 1/8 Miss Bud 73 mph
                Chris Craft 16 mph
                • Rumdog
                  • 6667
                  #38
                  10s in a Genisis should have very low amperage draw if it is setup properly.. Those packs, at their rating shouldnt have broken a sweat. Im guessing the setup is bad, or you ran the packs down too low.
