Power Options for 32" Deep V???
  • tanzi411
    • 114
    I have a couple 32" deep v hulls that need power options.
    Both are ABS plastic but i have re-inforced them with carbon rods and carbon fabric.
    Looking for both higher speeds and good run times. I have 120amp ESC's for both.
  • steveo
    • 1595
    what hulls are they any pics
    • tanzi411
      • 114
      I have a FDM 32 and a Kysho Jetstream
      No pics yet.
      • Alexgar
        • Aug 2009
        • 3701
        Maybe a cc1512 on 5s
        • tanzi411
          • 114
          I want to run Fiegao motors.
          Maybe a 9xl?
          • steveo
            • 1595
            i am sure a couple 9xl motors could get you in the 40 range but i have read that the fdm 32 does not handle so well over 40 mph now i dont know how true that is i am just saying as for the jet stream its an older hull who knows where its limitations are
            what was your goal in speed for these boats, if you are looking for high speed i dont think these are what you need?
            • tanzi411
              • 114
              High 30's low 40's is where i want to be. I much rather have the option of going fast and using it when i want.
              I also have a smaller 30" ABS cat hull that i am also building up that i need to power. May 9xl's in all?
              • Make-a-Wake
                FE Rules!
                • 6057
                Maybe a 9xl?
                Bingo! A couple of 2s 5000's in series and you'll have good speed and runtime.
                • tanzi411
                  • 114
                  What "C" rating should they be?
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    30c MINIMUM.........but for the small extra cost get 40c...................
                    Look how affordable lipos are now....................these are 45c 5000's for 25 bucks............and to the pessimists, i realize thats the "rating", but i bet its close. I run zippys in my 47" mono and they are great batts
                    http://www.hobbyking.com/hobbyking/s..._2S1P_45C.html
                    • tanzi411
                      • 114
                      sounds good!
                      Now about about a inexpensive charger?
                      Oh and we haent tlaked prop sizes for these 9xl motors and batts?
                      • MR2NR
                        Jet Stream EP
                        • Sep 2011
                        • 160
                        So are you going direct drive on the Jet Stream with the stern drive? I'm in the works with mine as well.
                        Kyosho K.I.T.T.
                        • video200
                          • 840
                          i have a FMD 32 and it works great on a 9XL and 4S2P with a X642. speed is around mid to high 30.
                          • Flying Scotsman
                            Fast Electric Adict!
                            • 5195
                            sounds good
                            There are no good inexpensive chargers, what are your goals?
                            Douggie
                            • MR2NR
                              Jet Stream EP
                              • Sep 2011
                              • 160
                              Douggie
                              They also used to say that about the Tx's untill Flysky came around. Have you seen Gen Ace's?
                              True QC isn't has good but hey I'm impressed.
                              Kyosho K.I.T.T.
