Major Accident The Canadian Dream Crash
  • DBQuick
    • Aug 2011
    • 55
    Had a Major Accident dont know what it hit Turtle / Fish / Tree root floating on the lake but SOB it crack the rudder support almost pulled it off any one out there willing to fix it I don't have the resources to do this the money yes resources no Boat wreck 021.jpgBoat wreck 020.jpgBoat wreck 019.jpg can any one help ?????
  • driftah
    • 759
    um yup but you gotta pay for shipping and materials,possibly some paint too lol,I had the same thing happen to my df26 two weeks ago...what hull is yours?
    • m4a1usr
      Fast Electric Addict
      • 2036
      Its a UL1 from the photos. Oooch. I can feel your pain. That was a hard inpact! After its been repaired consider a shear screw on your rudder. When running in waters where there is known hazards its a good idea to run a nylon lower screw to prevent what happened to your hull.
      John
      Change is the one Constant
      • DBQuick
        • Aug 2011
        • 55
        Its a UL-1 No problem on paying for shipping and materials and what ever else it needs let me know were to send it,and estament as to how much it will cost.I will pay in US denomination or what ever.
        • dasboata
          • Dec 2010
          • 3972
          I can fix it but I am in NY, email me if interested dasboata@aol.com
          • Chenige
            • Jul 2011
            • 201
            How do you guys fix this? Just want to see methods.
            Put in a doubler transom? Pushing/clamping the broken area back in with epoxy? Cutting out the broken area and fiberglassing in?
            • dasboata
              • Dec 2010
              • 3972
              it's not a big deal ,, some fiberglass matt or cloth some filler and some sanding and paint !!
                It needs a proper transom reinforcement or it will happen again unless you killed the turtle, etc...
                • HYDROJERRY
                  • Jan 2010
                  • 2709
                  That sucks DB,, next time be sure to put a plastic screw threw the top bolt hole so the rudder can brake away and not damage the hull,,
                  • egneg
                    • 4759
                    That's not to bad,this is major damage ...
                    IMPBA 20481S D-12
                    • Stinger9D9
                      • 378
                      Same thing happened to mine up north this year. The problem was, I didn't realize I had lost all steering until the boat was headed straight for the dock at full speed.
                      Instead of transom-only damage, the boat wound up plowing right into one of the posts of the dock and cracked the hull all the way from front to back.
                      I wound up buying another hull (not cheap). I might try some work on the broken hull, but I have a backup in the meantime.
                      • Alexgar
                        • Aug 2009
                        • 3701
                        Mine is the exact same I hit something to you would think they planned for this
                        • driftah
                          • 759
                          the transom seems like it would have to be trimmed out from the rear....doubled from inside then reinstalled and glassed then comes the filler and then paint.This hull has a sealed off hull, so no access to it from inside.
                          • dasboata
                            • Dec 2010
                            • 3972
                            You can't get to the back of the transom how do you put nuts on your hardware ? I would also put wood or CF back there to reinforce more !!
                            • morewattsnow
                              • Oct 2010
                              • 236
                              You use a steel bolt in the top and a shear bolt in the bottom hole. On impact it pivots on the top bolt, breaking the bottom one when the rudder kicks up. A shear bolt in the top hole will do no good.
                              Fast Electrics Have A Small Carbon Wake
