Stuffing Tube Gease NOT to Use?
  • sanyijr
    • 377
    So I have seen post after post on the different greases and grease/oil mixtures out there that work. What should you (I) stay away from as far as flex drive lubes. (besides KY or beacon grease )
    I know some bearing greases will infuse water and actually sortof foam and cuase lots of friction. And I suppose some greases are too tacky or possibly expand under heat? And definite no no's here?
    -Sean
  • m4a1usr
    Fast Electric Addict
    • 2036
    I would stay away from Silicone based Greases. They are not typicaly high pressure greases (thats what you want to use) and can become gummy over time. I'm sure others know of similar products.
    John
    Change is the one Constant
    • jkr
      FE Addiction
      • 582
      I use the Pro Boat Marine Grease with no problems so far.
      • madmorgan
        • 152
        stay away from gun oil
          Don't use general products like 3-in-One or WD-40. Thin oils are usually not a good idea. Marine greases, 70W+ gear oil, and commercial R/C cable grease are the best bets.
          • DBQuick
            • Aug 2011
            • 55
            Hey Fluid what do you think of Quick Silver 2-4-c Marine lubricant with Teflon that's what i am using ????
              Commercial marine lubes should work fine. They may or may not be the "best" but they work very well.
              • T.S.Davis
                • 6266
                Me too. That's my favorite to date.
                Noisy person
                • ManuelW
                  • Oct 2010
                  • 786
                  Same for me, using the Quicksilver 2-4-C in all my boats up to the HPR 135 SAW project for several years now. Can especially recommend it for use in the HPR arneson drives and the ball-beared prop shafts.
                  best regards,
                  Manuel
                  • DBQuick
                    • Aug 2011
                    • 55
                    Thanks guys I wasn't sure but now i am thanks again
                    • Cooper
                      • Jan 2011
                      • 1168
                      Auto parts store, brake caliper grease, high temp corosion resistant , doesn't foam , tackey yet viscosity thin enough at temp for wire drives and flex cables, stuff works good
