Genesis prop shaft help
  • pegasix
    • Jul 2011
    • 9
    ok so i picked up a used genesis cheap
    but the problem is the stock prop shaft housing is bent/kinked
    i need to replace it but i come across no real information stating what size or where to pick it up form my LHS has nothing for boats so
    HELP
    what measurments i need and where if anywhere to get such an item
    thanks
  • HYDROJERRY
    • Jan 2010
    • 2709
    If it is all stock,, before you get the original parts,,everyone changes that stuff over to 3/16 flex,,i recomend you do this also and you will need to convert the strut to accept 3/16 shaft,,,
    • stadiumyamaha
      • 1371
      Its an easy fix. Drill out the stock bushings in the strut and replace with 3/16 teflon bushing then buy a sv27 flex cable at ose and also a .150 collet.
      • ponti454
        • Oct 2011
        • 1
        i have a conversion kit on my website for that. www.rcboatbitz.com.au and look under genesis upgrade parts catagory
        cheers
        • Alexgar
          • Aug 2009
          • 3701
          Fightercat racing could help you out with parts and if you do drill it out use a hughey or octura flex it might save you the price of a prop. Those flexes are far superior to a sv27 flex
