Need help with wingrush
  • dogie456
    • 6
    I bought an ebay boat (wingrush) and want to replace the twin props and 380
    size motors with a 540 size car motor and hpi e10 electronics. i have already
    made a rudder and attached it but i don't know the best way to attach the
    single shaft. I was thinking maybe to take one of the old shafts and drill a hole
    in the hull and put it through there but im not sure if thats a good idea. I am
    also thinking about putting 2 batteries in but im not sure the speed controller
    will handle it. alternatively i have ordered a Li-Po of ebay which should arrive
    soon.
  • ReddyWatts
    • 1756
    How long/wide is the V hull?
    I always wanted to convert a hull like that for fun, now that you can find cheap controllers.
    If it is the one I think it is, I would use a Fiegao 8S motor with atleast an 80 amp controller, 120 amp is even better on 2S lipo, x430 prop. It will draw about 65 amps and will run in the 20's and will be fun to drive, if you can keep it on the water.
    ReddyWatts fleet photo
    • SJFE
      • 4867
      As always Mr. Watts has suggested a good powersystem. I would not run car eletrics. It can be done but it will not be much better than stock. For your drive cable question pick up a drive tube and cable system here on ose. It is inexpensive, easy to install & maintain. You will need some type of strut for the propshaft. An aquacraft stinger or octura skeg strut are another cheap option & can also be found in the store. The best way for us to help you is start a thread in the boat building section take some pictures and post them up.
      Good luck & have fun
      Tom G
      • dogie456
        • 6
        wingrush
        thanks for your help. the dimensions should be the same as an NQD high wind
        thanks again ill post a new thread in the boatbuilding section and keep u guys up to date.
        • SJFE
          • 4867
          I look foward to it. I really dig projects like this
          • dogie456
            • 6
            Australia
            the problem is that i live in australia and that would make the potage stupidly expensive. Do you guys know any good links for shops in australia. any links would be greatly appreciated thanks for your help
            • dogie456
              • 6
              Fiegao 8S motor?
              i couldn't find the feigao 8s motor on the website. is it a 540 size?
              i also found this motor.
              http://cgi.ebay.com.au/Monster-540-s...QQcmdZViewItem
              • ReddyWatts
                • 1756
                540 8S 4,436 RPM/Volt 1/8" Shaft
                http://www.offshoreelectrics.com/pro...?prod=fei-540S
                Water cool it.
                • dogie456
                  • 6
                  thanks
                  thanks a lot mr Watts
