Water sanding epoxy coating
  • jj2003
    HIGH VOLTAGE ADDICT!
    • May 2011
    • 1710
    Anyone have ANY experience in water sanding an epoxy coating? I sealed my decals into my CF hull and have some ripples I'd like to sand out and apply a final coat to smoothen it out. I'm just not sure if it would work the way I would want it to. I have water sanded paint before but never epoxy. Any suggestions please chime in, thanks ahead, JJ.
    "If guns cause crime, all of mine are defective"
    45"Speedfreek
    , Fightercat #068 ​, MyYoutube Vids
  • egneg
    • 4759
    The benefit of wet sanding verses dry sanding for both are the same, it helps to keep the paper from loading up.
    IMPBA 20481S D-12
      Another advantage is preventing melting of the epoxy - not an issue with paint.
      • siberianhusky
        • Dec 2009
        • 2206
        Also depends on the type of epoxy, some cure to a much harder finish than others.
