Lso. Lsh ???
  • magnum500sw
    • Jan 2009
    • 97
    Lso. Lsh ???
    What are some of the abriviations used in racing ?
    Sorry for the newb question
  • sailr
    • 7128
    LSO= Limited Sport Offshore or Limited Spec Offshore
    LSH = Limited Spec Hydro
    Mini Cat Racing USA
    www.minicatracingusa.com
    • magnum500sw
      • Jan 2009
      • 97
      So what are the others ?
      • sailr
        • 7128
        There are too many to list here. There is rigger, mono, hydro, tunnel, cat, scale, etc. Some of the classes are "limited" to certain motors and batteries. Others are open, motor wise, and are designated with different identifiers for the battery power in that class. For example, "P" designates 4S batteries, "Q" designates 6S, etc. etc. etc.
        It can be a bit confusing. You should telll us what size and type boat you are interested in and we will point you in the right direction.
        Download the NAMBA rule book and go to electric section. http://www.namba.com/content/library...a_rulebook.pdf
        Mini Cat Racing USA
        • magnum500sw
          • Jan 2009
          • 97
          1/8 scale hydro
          • sailr
            • 7128
            There is no limit to what motor/esc you use in 1/8 scale. Batteries, depending on KV of the motor used range from 8S to 12S. Section 21 in the NAMBA rules is about 1/8 scale. Further info is in the electric section. Lots of rules regarding the placement of the prop/strut location, etc. Also scale points for realistic scale reproduction of full scale boats.
            Mini Cat Racing USA
