ESC issues feigao 8xl and 60 amp esc
  • splong15
    • May 2011
    • 32
    Running a feigao 8xl motor with a 60 amp aquacraft esc.
    I am experiencing delay in the response of the esc. When I back of the throttle it takes another second or two for the boat to respond. I have checked connections and put fresh batteries in transmitter, same problem.
    any ideas.
    Thanks
  • Make-a-Wake
    FE Rules!
    • 6057
    I cant believe the 60a hasnt already fried using an 8xl with it......................go with the Turnigy 120a
    • 785boats
      Wet Track Racing
      • 3423
      Have you made sure that it's not a receiver problem first? Plug a servo into the throttle channel & see if it responds properly.
      I agree with Make a Wake. A 60A ESC is a bit small for an 8Xl. Depending on boat type & size & of course the prop size.
      Paul.
      • 1truckerdan
        • Aug 2011
        • 344
        What are the batteries? How do you have them set up? 2s x 2 or?????
        Daniel
        When you know it all.......you never will learn anything new
        • rearwheelin
          • 2101
          Need atleast 120amp esc as previously stated. 90 amp motor.0
          --Albert Einstein
          • 1truckerdan
            • Aug 2011
            • 344
            If he it running the 8xl on just 3s wouldn't that 60a esc be able to handle it?
            Daniel
            • rearwheelin
              • 2101
              Daniel
              When volts go down amps go up. It is going to depend largely on his prop how long his esc will last. The key is to allow the motor to run efficiently. Very hard to do with a 60 amp esc when the motor wants 90 amps. Esc will not last.
              --Albert Einstein
              • splong15
                • May 2011
                • 32
                Thanks for all the info. I am new to boating, and bought this boat used. My options are now to either get new a esc or new stock motor.
                The 8xl is almost to fast for the boat.
                I am running 2s x 2 5000 mah 40c
                Any suggestions
                • splong15
                  • May 2011
                  • 32
                  Does anyone know of a forum in here that explains the amp esc to motor demands
                  • 1truckerdan
                    • Aug 2011
                    • 344
                    Here
                    http://www.offshoreelectrics.com/conversion.htm
                    bottom portion of the page
                    Good information.
                    Daniel
