eagle tree
  • magnum500sw
    • Jan 2009
    • 97
    eagle tree
    i know some of you are running an eagle tree data logger . what did you do to keep it safe and
    dry ? i may be able to cram it into the radio box but it may be tight .
  • ksm2001
    • 397
    I used Plastidip on mine. Use a small brush and paint it on and in the gaps, its available here on OSE but I see Steve is out of stock. You can purchase it at some hardware stores or you can try Corrosion X.
    DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
    • 1truckerdan
      • Aug 2011
      • 344
      Also a balloon works pretty good to keep it dry.....and is removable and warantee friendly
      Daniel
      When you know it all.......you never will learn anything new
      • oscarel
        • Dec 2009
        • 2373
        Conformal coating works as well and is warranty friendly.
        • 1truckerdan
          • Aug 2011
          • 344
          Thank you for the info on the Conformal coating being warranty friendly.
          I did have a traxxas vxl esc that they wouldn't cover under warranty because I put liquid tape on the case around the wires and it was touching the board.
          Daniel
          • oscarel
            • Dec 2009
            • 2373
            Yeah, I made sure to ask before doing it.
            • lohring
              • Jun 2011
              • 205
              In gas and nitro boats we put our Eagle Tree loggers in a balloon. That wasn't good enough in the greasy and high vibration environment of those boats. Our loggers had a fairly short life. We were also careful to power the logger with its own battery because ignition noise got back to the receiver. None of these issues should be a problem with electric boats. However, in our full size electric hydro we had to keep the Eagle Tree loggers away from the motor. The magnetic field fried a logger we put on the motor. That motor easily pulled 700 to 900 amps at 140 volts. The Eagle Tree units were never designed for that kind of environment.
              Lohring Miller
              • magnum500sw
                • Jan 2009
                • 97
                O.S.E sells this coating ?
                • magnum500sw
                  • Jan 2009
                  • 97
                  Lohring Miller
                  Full size ? I know that's off topic but is there video of this.
                  • oscarel
                    • Dec 2009
                    • 2373
                    I buy it from Fry's. Amazon also has it http://www.amazon.com/Acrylic-Lacque...4458649&sr=1-1
                    • 1truckerdan
                      • Aug 2011
                      • 344
                      What about "Silicone Conformal Coating?
                      MG Chemicals produces a range of silicone conformal coating products that offer enhanced heat resistance compared with other chemistries. These 1-part systems are fast curing, flexible and flame retardant, making them a suitable choice for many applications that experience a wide operating temperature range. These products are available in a variety of packaging options, ranging from aerosols to bladder packs, so they can accommodate almost any processing need. We also offer acrylic, polyurethane, and UV conformal coatings.
                      Would this work ......as good......or better.
                      Has anyone tried it yet?
                      Daniel
                      • 1truckerdan
                        • Aug 2011
                        • 344
                        I thought this was a good place for more info about Conformal Coatings
                        Daniel
                        • oscarel
                          • Dec 2009
                          • 2373
                          OSE also sells this but out of stock now, I have not used it though.
