Would a coupler for 4mm brushless motor shaft fit a 3.15 mm motor shaft with minimal difficulty? If no anyone have suggestions for a coupler that'd fit a 3.15mm motor shaft and also a .150 flex cable?
Drive coupler question.
Welcome to the Forum Ian,
You don't really want to use a 4mm coupler on a 1/8" shaft. The coupler will wobble excessively and eventually break the cable and/or the motor shaft. They make 1/8" to .150" cable couplers although they are a little scarce at the moment.
The OSE shop carries them, but they are out of stock at the moment: http://www.offshoreelectrics.com/pro...rod=ose-str-ci
Jeff Wholt usually carries some as well, but he is closed till the end of August: http://www.rcraceboat.com/
TylerTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Not really any cheaper methods for a flex cable.Tyler Garrard
