what is the best paint for wood boats?
  • iceman
    • Aug 2011
    • 74
    im planning on spraying my rigger with a hvlp spray gun. what paint will give me the best finish? i plan in using more then one color so i will be doing some taping so dont need any peeling. plan on several clear coats to seal. thanks for the help.
    GARY
  • rcboatmanwithkids2880
    • 348
    Hi Iceman ,
    Just about completed my current Dumas tunnel project in black with spray - can enamel , just need to put a clear coat over when i'm satisfied with pinstriping etc. . There may be a better finish , but i don't want to be to fussy & it's pretty good anyway ....
    All the best in F/E R/C Boating ,
    Brad
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
    • Chenige
      • Jul 2011
      • 201
      Automotive paint will probably give you the best finish but it is expensive.
      I am using rustoleum spray paint right now and regretting it. I guess if you were just putting on one color it would work fine but if you do a bunch of colors with taped designs in between colors and a clearcoat it stinks. The already applied layers wrinkle, even if you do wait the 24 hours inbetween.
      In the past I used Omni auto paint from PPG and it is their inexpensive line and worked great with nitro fuel. I called today and they are replacing it with Shopline.
      • longballlumber
        • 3417
        GARY
        Klass Kote is highly recommended by the Nitro and Gas boat crowd. I recently used for the first time on my FE Phil Thomas hull (fiberglass). It was easy to use and very forgiving. Only downfall is they have a limited amount of colors to choose from.
        Later,
        Mike
