Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 rudders and struts for riggers - RcBoaters Forum
  • iceman
    • Aug 2011
    • 74
    in the back of my scratch built rigger my plans are to have two 3/4 pads what size rudder and strut do i need? do i need duel water pickups sense im planning a water jacket for the motor and a water cooled esc. any help would be great.
    GARY
  • Boaterguy
    • 1779
    usually the rudder is about 15% the length of the boat. you can run two pickups if you want but one should be enough unless you are pushing your equipment
    • carlcisneros
      • Jan 2010
      • 1237
      how long is the hull goingto be?
      • iceman
        • Aug 2011
        • 74
        Carlcisneros, its 22 in. long and 4 in. wide
        • carlcisneros
          • Jan 2010
          • 1237
          this is a good rudder from OSE
          http://www.offshoreelectrics.com/pro...prod=ose-80052
          and depending on the height of your transom, this strut should work.
          http://www.offshoreelectrics.com/pro...d=ros-21-strut
          use the round bottom version
