another villain build- help.
  • NorCalZ71
    • Jul 2011
    • 311
    thanks for the links!. those jet black turnigys look nice!.. im looking at this one though only cuz the company is more local.
    • NorCalZ71
      • Jul 2011
      • 311
      well its been a while. i got a swordfish 120a esc and an x440 prop. and the proper flex coupler.. i ran it today on 14.4v nimh and it was slower then before. but the new prop is substantially smaller..
      gonna prop up and see what happens. kinda stuck with nimh batts for now. till i upgrade motor and can afford new 3s lipos.
      i was given a pair of common sense 3s 3150mah batts but they are only rated at 8c or 25a continuous or 37a burst. would they work? or will i puff em?
      running a rimfire 1200kv outrunner. specs for motor here. model GPMG4620 http://www.electrifly.com/motors/gpmg4505.html
      ill run the x440 on 6s not the prather 265 i ran in the video.
        • 6057
        My word..............you ran a prather 265???? Thats so large it borders on ridiculous........in fact it is. Run the nimhs, i wouldnt mess with those tiny lipos. That motor is still on the small side but try it with your smallest prop first.
        • NorCalZ71
          • Jul 2011
          • 311
          yea ill try again on nimh with the x440 and see what i can get out of it. i may try it on 22.2v nimh again to see what the x440 can do.
          • NorCalZ71
            • Jul 2011
            • 311
            o yea that vid was shot with the 265. on 6s i borrowed 2 3s 5000mah maxamps packs and everything ran cool except the motor but its only rated for 4s so i figured thats why it got hot. and it only got up to around 150*
            • NorCalZ71
              • Jul 2011
              • 311
              i worked a deal with a friend on getting a motor for this beast. what can i expect speed wise for this motor on 4s lipo? tacon LBP3674-B/5D-1300KV
              ill be playing with settings 2moro and ill try to get another vid.
              • NorCalZ71
                • Jul 2011
                • 311
                • NorCalZ71
                  • Jul 2011
                  • 311
                  I ended up getting a proboat 1500kv motor from a friend today so I tossed that in. Ran that with the sf120a and x440 and it ran nice. Right around 26mph on nimh. Borrowed a pair of 2s 5300mah lipos and swapped the graupner k series 48mm prop on and ran 31mph. Borrowed a pair of 3s 5k packs and ran in the mid 30s. The gps shut off mid run and the packs dumped before I realized that.. ill get better gps readings next week. I think my turn fins are too low in the v so I may be removing them and moving them out a bit more. They cause the boat to cut hard corners under acceleration. Probably due to the hull flexing from motor torque and causing the turn fins to act like rudders.
                  Sent from my T-Mobile G2 using Tapatalk
                    • 6057
                    What prop did you use in the vid. It runs well that way..................you may wanna just keep it like that since its about twice stock speed and looks pretty stable....................just keep it all cool and enjoy it, dont start overvolting and over propping it.
                    • NorCalZ71
                      • Jul 2011
                      • 311
                      That vid was 6s on the graupner 48mm carbon prop. I'm already on par with my friends stock impulse with 4s on that prop so I'm gonna order a pair of 2s packs. From there ill play with props to see what I can squeze out of it. Ill eventually get a pair of 3s packs but I think 4s will be good for now. I have a vid of it on 4s ill upload in a min. I'm gonna shave those turn fins off this week though. I think they are causing the handling problems.
                      • NorCalZ71
                        • Jul 2011
                        • 311
                        4s lipo and high winds.
                          • 6057
                          This ended up as a nice boat.
                          You'll never guess what i'm starting on right now..........................yep, another Villain, but this time its gonna be a wolf in sheeps clothing. stock outdrives, stock gear reduction, but twin 3656 brushless!!
                          • NorCalZ71
                            • Jul 2011
                            • 311
                            Gotta see that! I still have a stock ex to mess with!...
                              • 6057
                              How's this dude runnin'?
                              • NorCalZ71
                                • Jul 2011
                                • 311
                                Stripped it down for now. Need to reinforce the hull so motor went on a k&b outboard for the hornet.. lolz
