well i have an old villain 4 Im gonna modify. i have already ordered a water cooled motor mount and I am in the process of removing the inner compartment. i will be laying down a layer of fiberglass along the length of the hull and i plan to double it where the motor mount will be set. i will also be adding light ply or thin carbon fiber plate as a transom doubler. i am still unsure of what rudder i will use and I am clueless on the drive setup. I'm not sure if i wanna run a solid 4mm shaft or if i should go flex. cost wise flex is going to be more expensive because of the more parts it requires but it will be more adjustable. but im running on a low budget
the biggest problem im having is where do i mount the motor? if any of you villain vets have any suggestions they would be greatly appreciated. and ill post pix here as work on it progresses.
ps i will be running this on a rimfire 1200kv outrunner to test. i had it laying around and it fit the bill. im still looking for an esc but i plan to run 4s. maybe 6s if the temps stay down.
