Revised math calcs/motor determination
  • Chenige
    • Jul 2011
    • 201
    Thanks for all the help. As I stated before my new charger is stopping charge before the battery is fully charged. So instead of 50 seconds run time I actually got 10 minutes. Charger put ~3600 mAh back in.
    20" mono electrified, 15T speed gems 2 (4006 kv), X432 prop, 7.2V 3800mAh NiMH battery, 35 max amp Astroflight ESC
    Perfectly flat water so ran wet, not as fast as expected. However I ran later with a little chop and it scooted across the tops of the chop beautifully. Could run at full speed with no controllability issues.
    Max rpm= 4006 x 7.2 = 28,800 rpm, 20,200 RPM loaded (per OSE calcs)
    Amps=(3600 mAh/1000)/(600 sec/3600)=21.6 Amps
    Watts = (amps) x V = 21.6 x 7.2 = 155 watts
    Top speed per OSE calcs= 33mph
    I confirmed numbers on OSE speed calc link.
    At the end of run:
    ESC barely warm
    Motor very hot
    Battery was slightly warm.
    So now I want to pick a brushless motor/LiPO combo to put into 4 more boats. Must be inexpensive and hopefully a bit more boat speed.
    Turnigy 36-56-04 2600kv Inrunner on 3S 5000 mAh, $20 http://www.hobbyking.com/hobbyking/s...idproduct=6527
    Max RPM=2600x11.1=28,860 RPM (same as current boat), 23,100 RPM loaded
    Rated Watts=475 therefore max Amps=43 on 11.1V
    Run time =7 minutes
    Top speed per OSE = 38mph
    Is this a good replacement combo? Numbers seem to work but I have no idea if it is the best combo. Are the rated wattages accurate for these motors? There are plenty of other Turnigy choices.
  • siberianhusky
    • Dec 2009
    • 2206
    Just saw a 2300kv version of that motor go up in smoke last week for no visible reason, was in a SV27, temps were ok, boat had been run that way for a number of months. 3:15 into a run right as he was turning to bring it in it just quit. ESC survived but all the insulation melted off the motor leads.
    It was a well tested good running setup, up till then. You'd want at least a 90 amp esc, that motor puts out way more than the listed 475 watts. The one that smoked was running a aquastar 90 esc.
    Honestly I'd look at nitrorcx for a tacon motor, be a bit more money but cheaper in the long run. Might actually end up being cheaper as it's being shipped from California instead of China.
    • Chenige
      • Jul 2011
      • 201
      Those Tacons in 3650 size just seem a bit too much for this boat? 900 Watts! However the amps on this one is 41 so perhaps it would work? Guess I am confused on how they get amps and Watts. Should not a 900 watt motor use 81 amps on 11.1V? Or the opposite 41 Amp x 11.1V =455 watts?
      Would really like to get a motor that allows a 50 amp ESC. Gotta believe there is something out there since the boat runs great now with a 35 amp ESC.
      Price is OK at $28. 2230kv may be a bit low but loaded rpm = 19,800 which is just less than the loaded RPM I have now (20,200).
