Hay bud's got my new df 33 and I'm so happy fast shipping thank's to steven at ose,But I didn't get the rail's . I was going to cut some basa myself,But then came up with something new at least I haven't seen it yet,Can anyone tell me who can cut me some alluminum rail's,for my motor to mount to about 1''1/4 high and 15'' long with the bottum of each on a 60 degree 's angle,who do I need to talk to.
df33 rail's
Hay bro that guy who did my servo mount is here,,,ask him, http://forums.offshoreelectrics.com/...or-mount/page4
Whatever you do don't use balsa for motor rails, that will be way too weak and will fail in a hard crash. As far as aluminum rails, a few extra ounces of weight will do nothing to the performance of the boat, while it will give higher reliability in the event of a crash. If you're scared of aluminum, then use 3/16" plywood from the LHS.
I try to keep conductive materials to a minimum in my electric boats.
WOOD is GOOD. Do what Fluid says.Mike Chirillo
www.capitolrcmodelboats.com
hay bud can it be 1/4 of a inch thick ,take a look at this picAttached Files
please listen to Nautiboyz.
Keep conductive material to a MINMUM inside the hull.
and 3/16" ply is fine for the stringers.
1/4 and up adds more weight.
just take you time and do a nice neat job of installing them. (don't over do it with epoxy as it only adds weight.)
I have a used 33DF that I will be installing stringers in and the thickest I will use is 3/16" ply.
And you don't have to stay at 1 1/4" tall all the way on them as well. you can start out at maybe 1/2 inch, then go to what ever heighth you need
for your mount, then decrease it back to 1/2 at the transom.
What ever material you use. After you epoxy the stringers in, get some 1" or 1 1/2" fiberglass cloth tape and glass those stringers in. They will never come off in a flip or stuff. I only glass the inboard side of the rails and then lay a bead of expoxy down the outboard sides where the rail meets the hull.Mike Chirillo
Thanks guy's from VA ,I 'm goin to go with carbon fibber,sorry for being a hard head,Originally posted by carlcisneros View Postplease listen to Nautiboyz.
