Delta Force 33
  • nova68
    • 211
    Delta Force 33
    I have a Delta Force 33 with a NEU 1515/1Y, ESC is a Hydra 240 LV, Prop is a Octura X 442 and I want to set the low voltage cut off to 15 volts is that to low ??????? Can use a little HELP and THANKS
  • Rumdog
    • 6667
    I'd hope you're only running 4s..
    • Chilli
      • 3204
      I believe most people using low voltage cutoff set it at 3.2-3.6V per cell. IF you're using 4S packs, 15 volts comes out to 3.75 volts per pack. You're well within the safe range. Your packs will stay cooler and last longer.
      Mike Chirillo
      www.capitolrcmodelboats.com
